    [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
    137 Posts 49 Posters 145.8k Views 49 Watching
      Do you have permission to write files to the destination folder ?
      Try your Desktop...
      Is there any exportable geometry in the SKP you are trying to export... etc ?
      • SygskyS Offline
        Sygsky
        Try your Desktop...
        Yes, yes, yes and yes all times 😎 But suddenly I found the solve. Don't sure what was an origin for the problem, so only describe result:
        Rubi is not one of my multiple languages but throw the code I found that in some checks if any external/internal functions in module return nil, it exits without warnings. As last action I did is a file name pointing, I tried to set full file path manually in the input dialog field, e.g. "C:\Temp\1.kml", not only name as it show in system dialog itself ("1.kml"). And it worked! So as I can suppose, alone file name is used internally to be used with some standard prefix of directory different from one used in a real path, use din dialog.
        Why? Windows 64b 7 Professional and Rubi pair knows only/ So export problems is solved. Let me check import ones in next time 😮)
        Thx for the wishes to help for this small problem!
          KentD
          Hi Aerilius
          I´ve used your plugin now and it seems to really work.
          I have to export a whole modeled city and I want them to be separate models.
          Your plugin does the trick! I make components of every and each model an export them.
          BUT if I have to ROTATE any of my models they will be exported randomly(it seems) and NOT in their right position.
          Any good suggestion how to deal with this?
          Regards
          KentD
            Aerilius
            The plugin should consider the rotation of the group's/component's bounding box.
            If the group is rotated, the rotation will appear as a "heading" attribute in the KML file, while the Collada file contains the group's inner coordinate system. At least it should work that way. Can you send (pm) me a file where it doesn't work that way?
              SBMattingly
              When using this tool that I just downloaded, I get a small window first that says "Loading correct elevation data failed. Internet Explorer 8 (or higher) required." I have IE 8 and SU 8.
              Ruby console says the following: "fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=37.355313&lng=-108.385784&username=demo&style=full&callback=returnJson
              returned:
              {"status":{"message":"the deaily limit of 30000 credits for demo has been exceeded. Please use an application specific account. Do not use the demo account for your application.","value":18}}
              Please help. I would love for this plugin to work.
              Stan
              • H Offline
                humbertoanastasia
                Hi there! Thanks for the plugin.
                I'm having an issue, though.
                I try to export an object, the dialog box opens, everything ok, and then...
                Sketchup and the plugin just stop working.
                Any ideas??
                Tanhks!
                  Aerilius
                  What happens? What does "stop working" do?
                  And it's good if you tell me the file size, as described anything larger than some hundred kilobytes will take long. There is no simple way to make it faster.
                  • H Offline
                    humbertoanastasia
                    Thanks for the reply.
                    In fact, after I read your post, I tried "cleaning" the file, and minimizing it to the sole part of the model i wish to export. And... It worked out fine!
                    Thanks, and congratulations on your job!
                    • coda13C Offline
                      coda13
                      thank you very much!
                        Aerilius
                        **@thomthom said:
                        You're using a webdialog for the import - you can use the XML parsing capabilities of the web-browser:
                        http://www.w3schools.com/xml/xml_parser.asp
                        I'm working on a solution with a DOM xml parser.
                        It's more than 5 times faster than REXML (and probably much more in newer browsers). 😍
                          Aerilius
                          A quick update for compatibility with SketchUp 2013. It was released so quickly.
                          This is the last version before 2.0
                            Aerilius
                            I have uploaded a beta version of KML Tools 2.0!
                            If you like, please help testing and give me feedback if files don't work with it.
                            The new version has
                            • significant speed improvements, up to 7× faster import
                            • a reliable xml parser and better support for nested kml structures
                            • better error handling
                              kubark42
                              Just tried the beta, but it made no file output, just an empty directory. 1.4 works fine for me with the same workflow, so I'm either doing something wrong or it's not working on my model.
                              EDIT: Sorry, I should have included some info. This is OSX 10.8 running SU8. Model can be downloaded from https://www.dropbox.com/s/q5a1hzqvcwlc39u/Geo-fence.skp
                                kubark42
                                So this tool is really awesome, and almost exactly what I need. Thanks a million!
                                Time for a tiny bug report: when setting the altitude mode to absolute altitude, instead of adjusting the Z values to the true altitudes, the script just sets the altitudeMode field to "absolute". The result is that a model that was drawn on the surface is buried in the ground in Google Earth.
                                  Aerilius
                                  Thanks for the feedback! I'll check your file and fix it.
                                    kubark42
                                    Okay, figured out the second bug, and why I wasn't seeing it before:
                                        if facecolor
                                          @out.puts "  <Style>"
                                          @out.puts "    <LineStyle>"
                                          @out.puts "      <color>#{linecolor}</color>"
                                          @out.puts "      <colorMode>normal</colorMode>"
                                          @out.puts "      <width>1</width>"
                                          @out.puts "    </LineStyle>"
                                          @out.puts "    <PolyStyle>"
                                          @out.puts "      <color>#{facecolor}</color>"
                                          @out.puts "      <fill>1</fill>"
                                          @out.puts "      <outline>1</outline>"
                                          @out.puts "    </PolyStyle>"
                                          @out.puts "  </Style>"
                                          @out.puts "  <MultiGeometry>"
                                    only places the <MultiGeometry> tag if there is a facecolor. So moving " @out.puts " <MultiGeometry>"
                                    " to right after the "end" solves the problem.
                                      kubark42
                                      Hi, Aerilius--
                                      I found out why I was having altitude problems. I don't program in ruby, but it looks close enough to other languages iI do program that I was able to muddle through it and realize that Altitude is not an attribute in GeoReference, so get_attribute("GeoReference","Altitude") returns 0. By changing Altitude to ZValueCentered, I was able to get a negative value in inches that is seemingly correct for my elevation. I cannot find a definitive reference on this, and there is also ModelTranslationZ which has the identical value for me, so I'm unclear which is the appropriate way forward. However, both solve my problem. So in conclusion, I've replaced line 253 by @ground = -@model.get_attribute("GeoReference","ZValueCentered").to_f.to_m and that solved my problem.
                                      Now I'm struggling with an odd error. For some reason when exporting a group to multigeometry the KML is missing the opening <MultiGeometry> tag, but it has the closing one. This causes an import error in KML until I manually add the XML tag.
                                      EDIT: terrain_alt([0,0,0]).to_m doesn't seem to return any sensible values. I'm interested if you have an idea about this, too.
                                        Kromaggs
                                        I'm using Bash under Window to dynamically generate a ruby script. This script allow me to import a specific KML file in sketchup and when the import is done I would like to export my model to KMZ file. This is an extract of my ruby script
                                        	# Impport du modèle KML.
                                        	model = Sketchup.active_model
                                        	status = model.import inKML, false
                                        	if status
                                        		# Suppression du modèle KML importé.
                                        		#File.delete( inKML )
                                        		# Export du modèle au format KMZ.
                                        		modelFile=File.basename( inKML, ".kml" )
                                        		exportPath = exportDir + modelFile + ".kmz"
                                        		model.export exportPath
                                        		model.entities.clear!
                                        		#Sketchup.undo
                                        		#Sketchup.app_safe_shutdown
                                        But the import KML plugin seems to give back the control to my script while importing, so the exported KMZ is not complete because the KML is not completely imported.
                                        Any idea about this problem ?
                                        • O Offline
                                          organicmotion
                                          "File seems not to exist.
                                          Please check that the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
                                          Am I doing something wrong? Took the KMZ file from gps opened in Google earth saved as KML then tried to import into SU with the KMLtools and I get the error above..
                                          any ideas anyone? Thanks, I am a beginner with SU 😄
                                            truga
                                            It appears that KML Tools are not yet compatible with 2014. I get the message:
                                            Error Loading File kmlDate.rb
                                            Error: #<SyntaxError: C:/Users/truga/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/kmlDate.rb:77: formal argument cannot be a global variable
                                            ...previewTimeLine") {|$kmlDateDlg, param|
                                            etc.
                                            • 6 / 7
