    Vray light - spot light (omni ?, IES ?)
    renderpluginsextensions
    7 Posts 3 Posters 9.7k Views 3 Watching
    • N
      ng0200731
      hi All
      I know very little about light, below is my model and rendered picture
      • when i place omi light or IES, and render it, nothing happened, may I know what else action should i do
      • only spot light helps, but it seems a little weird (i do not know how to say), any advice for me ?
      • any tutorial for VRAY for my reference ?
      Thanks all
      https://lh4.googleusercontent.com/-U7XfHRHqFuw/TewltOQL7qI/AAAAAAAAACo/3yfo4q503TM/s912/116.jpg
      • N
        ng0200731
        also, why there is no reflect of the light of the "black" wall ??
        any thing i need to set ?
        https://lh5.googleusercontent.com/-XD89-wkgfms/TexIxrZeJoI/AAAAAAAAAC8/4mv1OntXfaI/s912/116-2.jpg
        • N
          ng0200731
          hi All
          can anyone help me ? I have worked out 2 whole days to render, but it is not what i need
          can anyone help me, thanks (below i have added spot light and IES light)
          https://lh4.googleusercontent.com/-AdK2aJp4uyQ/Tez2lvnJi5I/AAAAAAAAADY/uGeDcvDbn1Y/s720/116-3.jpg
          • L
            ledisnomad
            Hi, ng0200731.
            Sorry that you are having trouble with your lighting. It looks from your most recent render you are starting to get something that starts to work. Do you know how to edit the properties of a light? As for the reflection of the "black" walls, do you know how to adjust the reflection of a material?
            If you aren't familiar with either of these, then I'd suggest starting with the manual: http://www.vray.com/vray_for_sketchup/manual/. This is how I learned the basics.
            Can you be more specific about what you are trying to achieve? Then maybe people can help more.
            • thomthomT
              Avoid using pure black and pure white - they are extreme colour values that can interfere with proper calculation of light.
              • N
                ng0200731
                @ledisnomad said:
                Hi, ng0200731.
                oh..yes, i have just browsed, there is lot of information, and I will read it tonight, thanks a lot
                it is really a great tutorial indeed
                • N
                  ng0200731
                  yes, sir, and will change it tonight, thanks thomthom
