    Model this: Snoopy
    Scheduled Pinned Locked Moved Organic Modelling
    15 Posts 8 Posters 11.6k Views 8 Watching
    • soloS
      solo
      I'm guessing at about this point everyone that is interested in organic modeling has purchased Artisan already, if not then I'd suggest doing so and playing along.
      Here is a fun challenge, and an easy one to start with, model Snoopy, in this pose:
      Please save proxy for sharing if needed as well as image of proxy's, in order to help others learn.
      Have fun (hopefully we will get some participation) πŸ˜‰
      http://www.solos-art.com
      • boofredlayB
        boofredlay
        I'm in on this one. I got a bit of free time now.
        Hopefully I can do a better job than I did on this one: http://forums.sketchucation.com/viewtopic.php?p=96189#p96189
        Of course I did not have Artisan then.
        • D
          deanlegg
          My first pathetic attempt 🀣
          • S
            SketchUpNoobie
            πŸ‘ Looks pretty close to the picture.
            SketchUpNoobie: the complete noob in all things SketchUp.
            • D
              deanlegg
              This method is ....er....interesting 😲
                Put the eye in the wrong place... πŸ˜’
                • soloS
                  solo
                  Okay, a quick go.
                  Proxy (very fast)
                  • EarthMoverE
                    EarthMover
                    Gave it a go. Made my proxy by a little different method. I used the line tool to trace the shape, then used TIG extrude edges by vector to create a quad strip outline. I extruded the edges again, then scaled them in from center. Repeated this 2 or 3 times to create the buldge and then closed the final shape. Then I select it all and run the reduce polygon tool in Artisan, once at 50% then again at 30%. Then I used smooth sculpt to selectively even out the vert clusters before running subdivide and smooth at two iterations. It seems to work out by starting with quads and then letting polyreduce iterate them into triangles before running SDS. It's a bit of reverse engineering, but was rather quick and painless.
                    Content Creator at Skapeup
                    • boofredlayB
                      boofredlay
                      Great work Adam!
                      I started one but life got in the way this weekend. πŸ˜’
                      • B
                        bjornkn
                        And here's my Snoopy.
                        I'm afraid only the tail and nose were made in Artisan - the rest in tgi3D/Amorph.
                        My first cartoon/figure ever in SU, so it did take a while.
                        With Bezier control curves shown
                        Wires - not quite low-poly
                        • B
                          bjornkn
                          Here's a less chaotic looking dump of the curves used.
                          • EarthMoverE
                            EarthMover
                            Stuffed Snoopy toy.......
                            • soloS
                              solo
                              Love the fluffy toy Snoopy.
                              Here is a quick scene with low poly Snoopy.
                              • D
                                deanlegg
                                Better than my first try πŸ’š
                                • O
                                  obgy2007 Newcomers
                                  so cool. thank you very much.
