    So easy...can´t finish :-)
    5 Posts 3 Posters 510 Views 3 Watching
    • tibetT Offline
      tibet
      hi guys,
      could you please tell me how to finish this"drop outlet" please?
      i can´t figured out, even it´s so easy 😄
      thanks
      the final piece should be like these
      http://i52.tinypic.com/o0qdeb.jpg
      SU 2015 Pro on Win10 x64
        Here's a quick screen grab....
        [flash=800,600:3ac54odl]http://www.youtube.com/v/JGIdpHCb3Go[/flash:3ac54odl]
        Used Artisan the smooth at the end
        • TIGT Online
          PushPull a Circle to make the lower cylinder.
          PushPull again +Ctrl to leave a seam to make another cylinder on top of that.
          Select the top circular edge of that and scale if about its center [+Ctrl] to make an inverted conical shape [like a funnel?].
          It's hard to see if the top part is circular - if it's not also scale the top in from a side [+Ctrl] to make it an oval.
          Group it all.
          Make a Circle on the Red axis and extrude it as a horizontal cylinder, move that so it intersects the Group centrally where the 'scooped-out' parts are.
          Edit the Group and 'select all', right-click context-menu Intersect with Model.
          Exit the edit and erase the horizontal cylinder as it no longer needed.
          Re-edit the Group and erase the unwanted parts to leave the 'scooped-out' dips in the 'funnel' part.
          Now form those little 'ear' bits... Assuming they are cylinders make a small one, inside it's own component and position [grouping will stop thing accidentally sticking together]. intersect with the model again and trim to suit. Copy the component across to the other side - Scale x -1 to flip it.
          Finally you can explode all of the parts and reconfigure into a combined new Component...
          • tibetT Offline
            tibet
            an excellent and quick answer, thank you guys!
            video tut is cool!
            what would be the world like without you.... 👍
            best of luck!
            cheers!
            funny, i thought curviloft plugin will do the magic...
            • TIGT Online
              @tibet said:
              ...funny, i thought curviloft plugin will do the magic...
              It [or EEbyRails etc] probably would,,, BUT they are really necessary... 😕
