    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    [Plugin] TextureTools
    106 Posts 34 Posters 101.9k Views 34 Watching
      @cadfather said:
      great plugin - would be fantastic if it worked on back-faces too
      But why is any textured material applied to back-faces ?
      They should never be seen !
      However, I have PM'd you a version to test called TextureTools_BACK ! which works like TextureTools but only on back-faces... It's a separate toolset and toolbar [it has similar icons but with a blue-gray background]
      Please test and see it it's what you expected...
      • CadFatherC Offline
        CadFather
        Thank you TIG, that works great! πŸ˜„ πŸ‘
        basically since often i don't photo-render my drawings, the front-back issue doesn't arise.
        should i change my mind later i could always swap and even reverse faces with the su4you materials plugin: http://sketchucation.com/pluginstore?pln=S4U_Material
          If anyone else wants to try the 'TextureTools_BACK', please ask and I'm PM it to you...
            CadFather
            btw TIG, i tried unifying the 2 plugins, but i might as well work out the quantum/relativity problem first....... πŸ€“
            if you do join both scripts into one, PM me first please!
            • O Offline
              oip
              • Y Offline
                YuriNikolai
                Will you ever release a 2016-compatible version of TextureBaker?
                • 6
                • 6 / 6
