    [Plugin] TextureTools
    106 Posts 34 Posters 110.1k Views 34 Watching
      Copyright 2011-2014 (c) TIG
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      TIG-TextureTools.rb >> ../Plugins/ folder
      Plus script >>> ../Plugins/TIG-TextureTools/ folder
      TIG-TextureTools_code.rb
      Plus image files >>> ../Plugins/TIG-TextureTools/Images/ folder
      Click below to go to the PluginStore for more details and also download the RBZ ...
      http://sketchucation.com/resources/pluginstore?pln=TIG-TextureTools
        Thanks πŸ‘
        • massimoM Offline
          massimo Moderator
          Finally! πŸ˜„
          Thanks a lot for this TIG. πŸ‘
          Now a request πŸ’š : would be possible to add some move commands for the textures (for example the arrows buttons)? As you know moving precisely the textures is a real pain...
            I suppose that now that I have a 'proof of concept' in 'transforming' textures then as well as rotating, scaling or translation could be possible. A simple scaling about the center by an entered factor e.g. 2.0 is straight forward, and a translation by entering X & Y values [lengths] to shunt the texture along by on the face could be to - e.g. 100mm & 0 would shunt the texture to the 'right' 100mm...
            I'll see what's needed...
              Is there a difference except the process with the Right Click / Texture / Position / rotation yet existing?
              • massimoM Offline
                massimo Moderator
                πŸ‘
                Yes mainly two for what I can see:
                1)You can input a precise angle of rotation;
                2)You don't have to deal with that painful rotate+scale green pin.
                • srxS Offline
                  srx
                  Great! Thanks!
                  www.saurus.rs
                    There are a few glitches with non-quad faces etc but a fix is under way... as are the Shunt/Scale versions... watch for announcements...
                    • jgbJ Offline
                      jgb
                      Another useful plugin by the master.... TIG
                      jgb
                        Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
                        TextureTools expanded to include Rotate AND Shunt.
                        Traps now added for colinear vertices and > quad faces etc.
                        These tools now allow for accurate rotation of a texture anchored about the face's first vertex by typing in an angle in degrees into a dialog; and the shunting of the texture's UV-mapping [in XY/UV] by typing in two offset lengths into a dialog...
                        A third tool - 'TextureScale' - might follow if I ever get some spare time...
                        Feedback please...
                        • W Offline
                          wolfy
                          Quite handy, thank you!
                          • massimoM Offline
                            massimo Moderator
                            Thanks again TIG. πŸ‘ πŸ‘
                            Seems to work fine at a first quick try also with irregular shapes (just a little thing: if you don't copy the icon's folder in the plugins folder you get an error at the start of SU. The first version worked without icons).
                            That's really cool... 😎 Would be possible also to have a way to move the texture via keyboard (for example arrow keys)? I mean often you have to align textures each other or with an edge so a "fine" control on the movements with the keyboard would be really great. Something like the move tool of Photoshop.
                              I'll look at the code I must have messed something up adding the extra buttons etc...
                              The 'To Do' list could include a 'nudge' with arrow-keys option as doing it on screen might be little different from the Texture tool...
                                Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
                                I fixed the typo in the toolbar code so it should only make the toolbar and its button[s] if you have the icon[s]...
                                • N Offline
                                  notareal
                                  Sounds good, Thanks!
                                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                    Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
                                    A new tool Texture Nudge is added which allows you to nudge a texture in UV/XY using the four arrow keys, by a factor entered in a dialog or 10x if Shift is held down...
                                    feedback please - especially MAC users as I'm not sure about the key-codes...
                                    • massimoM Offline
                                      massimo Moderator
                                      Seems to work just fine! πŸ˜„
                                      A "must have" plugin. πŸ€“
                                      • massimoM Offline
                                        massimo Moderator
                                        A detail: the first time you start the "nudge" and the "shunt" tools you are obliged to input an increment because if you confirm the default number by just pressing "Ok" they don't work.
                                          I'll look at it... πŸ˜•
                                          EDIT:
                                          I recheck and it works fine... πŸ˜•
                                          Do you have the latest version? [I'm sure you do]
                                          The default for the setting is 1 unit - if you have mm it's likely to be very small - conversely with meters it'll probably be too much...
                                          What's your default template's 'units' ? mm??
                                          Zoom in to a corner to see if things move...
                                          Open the tool and hit OK without editing the dialog, you get the movement required.
                                          With the Nudge tool try holding down the Shift key as the movement is magnified by x10 so 1mm >> 10mm... Once you've set your preferred nudge or shunt values they are remembered across uses of the tool during that session.
                                          IF you want to have a default find @@u, @@v and @@d values near the start of the two tools class initialize and change the numbers there - e.g. '10.0' intsead of '1.0' will make the initial values 10mm not 1mm etc... πŸ˜•
                                          • OxerO Offline
                                            Oxer
                                            Hi TIG,
                                            I'm a mac user, i don't know the code of the mac keyboard but i have found a web page it's possible that help you
                                            http://wordherd.com/keyboards/
                                            [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                                            • 6
                                            • 1 / 6
