    Draw softened lines?
    4 Posts 2 Posters 353 Views 2 Watching
      Is there a plugin that draws softened lines? I'm testing a tool that requires some stitching and just want to speed up workflow. [sic : lazy bastard]
        Not that I know of... BUT you could easily recast the example linetool.rb, as slinetool.rb.
        Remembering to call the class 'SLineTool' instead of 'LineTool' wherever it occurs in the code, and redo the creation part thus...
        def create_geometry(p1, p2, view)
            line=view.model.entities.add_line(p1,p2)
            line.soft=true
            line.smooth=true
        πŸ€“
          I did that and placed slinetool.rb in the plugins folders. Typed load 'slinetool.rb' into ruby console once SU started. It worked but there was vanishing lines when picking points. I think the cursor was white?
          When I activated another tool I couldn't reactivate slinetool? Even ruby console said true after tying load command?
          It was nice while it lasted πŸ˜’
            PM me your ballsed up code and I try to fix it...
