    Spherical Camera
    renderpluginsextensions
    12 Posts 8 Posters 2.1k Views 8 Watching
      dizain
      Hello everyone,
      I had a problem with the spherical chamber vfs:
      360 ° FOV setting the render is completely black, while setting the FOV to 359 render fine. Why?
      David
      • N Offline
        nomeradona
        i use 359.9
        visit my blog: http://www.nomeradona.blogspot.com
          360 >>> 0
          359.9 >>> 359.9
          360.1 >>> 0.1
          If you rotate something 360 degrees it's the same as rotating it by 0 degrees...
            dizain
            Tig you're right but you just specify it in the manuals or
            when I write 360° the program automatically reads 359.9999°.
            David
              bjornkn
              I'd say that is a bug in vray?
              A hfov of 360 is pretty standard for a spherical, and with CGI you shouldn't really be limited by such rules/limits?
              Like with this photo-spherical that was rendered using Lightwaves advanced camera set at 360x520 degrees: http://worldwidepanorama.org/worldwidepanorama/wwp609/html/BjornKareNilssen-5626.html
              Set at hfov 720 degrees it would repeat the entire image twice horizontally.
              • P Offline
                pepa
                I see there's another problem. The more the number closer to 360° the more the picture is brighter. Does anyone know why?
                http://jsvizualizace.daportfolio.com/
                  dvd63
                  A mystical question??? ☀
                  • N Offline
                    nomeradona
                    yap i can see that.. i dont know the answer.
                      siramods
                      PROBLEM SOLVED.
                      But first, the problem description: black output from v-ray for sketchup v1.491 when using a spherical camera with a 360 FOV and increased brightness towards this value. After searching wide and far, this was the only forum the problem was plainly defined by others, so, after tinkering with the vray options for a good while, here is the solution:
                      For reference, I had reseted options before applying the following:
                      CAMERA > SETTINGS CAMERA > Type=Spherical, Override FOV=360, ON
                      CAMERA > CameraPhysical > OFF (turn off the 'on' check box)
                      • this will solve the black image, but still increased brightness
                        OUTPUT > Image aspect=2.0, width=2 x height, use any values (like 800x400)
                        ENVIRONMENT > GI Color=0.0, checked ON
                        ENVIRONMENT > BG Color=1.0, checked ON
                      • this will solve the brightness problem
                      Cheers.
                      And BTW, 360 ain't 0, nor this is a bug, just a bad documented feature.
                      • dkendigD Offline
                        dkendig
                        No, we actually do treat it as 0 for the physical camera. There are cameras out there that can do a 360 degree image or video, but they employ the use of multiple cameras and then stitch the images/video together. A physically accurate camera can't capture true 360 degrees with one lens.
                        @siramods said:
                        nor this is a bug
                        absolutely not, you are correct
                        You again, are absolutely correct
                        Devin Kendig
                        Developer
                          siramods
                          I stand corrected.
                            siramods
                            Related posts on this topic:
                            Rendering huge images with VRay 1.4 for Sketchup
                            http://sketchucation.com/forums/viewtopic.php?f=322&t=54220&p=491374#p491374
                            Make a render look like in the sketchup editor
                            http://sketchucation.com/forums/viewtopic.php?f=322&t=53980
