    Exact wall thickness
    3 Posts 3 Posters 367 Views 3 Watching
    • W Offline
      wheeljack
      Sorry if this is answered somewhere else. I did a quick search to find a plug in or something in the program that would do this.
      Basically, certain 3D printers require a minimum wall thickness. for some printable materials it's 1 mm for example.
      now I know for a simple flat side I can push pull to that thickness. However, is there a way that a complex or curved open shape (like a bowl) to be clicked on and "thickened" to a specific wall thickness? I've attached an image to better explain what I mean. The underside of this flying saucer is hollow. I want to make the blue or reversed sides extrude a couple millimeters. again, sorry if this is a simple thing and covered somewhere else.
      thanks guys! 😄
      • StilTegS Offline
        StilTeg
        I think there may be some plugin somewhere, but as I do not use them ... I would simply copy the surface, then scale it down, put it at the right place, create the flat and intersect everything to finish the thickness
        Curve Thickness.skp
        doing technical engineering on SketchUp ... without plugins
          Jim Foltz's 'simple_shell' will work on a manifold [solid] form [needed for 3d printing anyway?] - however, the wall thickness of a 3mm shell isn't exactly 3mm all round - it might do though [it uses scaling about a center]...
          Fredo's JPP [JointPushPull] has been recently updated to give a more constant thickness 'shell' - however, an exact constant shell thickness for multiple facets at a vertex is impossible to calculate...
          Note that you might have problems making very small faces [<~1mm] so scale x10 and then do the 'shell', then scale down x0.1 before exporting [small faces can exist but making them is the trip-hazard...]
