    Simpler formula for central angle?
    5 Posts 2 Posters 1.3k Views 2 Watching
    • jeff hammondJ Offline
      jeff hammond
      so i hacked this formula together but i'm feeling like it's too convoluted.. it works fine but is there a simpler way to find a central angle (circle) when the input is radius(r) & chord length(c)?
      2*(ACOS((SQRT((r*r)-(.25*(c*c))))/r))
      that's a combination of this:
      plus this for the d:
      sqrt(radius*radius-(chord*chord*.25))
      i feel like i should be able to use one of these (used for finding chord length):
      except i can't seem to get the chord and theta on opposite sides of the = and have it work out right 😳 😳
      (also,is there a better way to type r^2 [instead of (r*r)] that will work in a dc formula?
      thanks
      dotdotdot
        Use the 'Sine Rule':
        diameter = chord_length / sin(center_angle_subtended_to_chord_ends)
        and of course...
        radius = diameter / 2
        or
        radius = chord_length / (2 * sin(center_angle_subtended_to_chord_ends))
        rearranging formula...
        chord_length = diameter * sin(center_angle_subtended_to_chord_ends)
        or
        chord_length = radius * 2 * sin(center_angle_subtended_to_chord_ends)
        and to find the angle...
        center_angle_subtended_to_chord_ends = asin(chord_length / diameter)
        or
        center_angle_subtended_to_chord_ends = asin(chord_length / (radius * 2))
        Using your variable naming
        angle=asin(c/(r*2))
          jeff hammond
          thanks Tig
          (though i think that's for 1/2 the central angle.. but definitely what i was after.)
          fwiw, here's a rough version of what i'm using it for..
          it draws an arc with 3 different inputs -- radius, segment length, and # of segments
          select the component then use the component options dialog
          i don't necessarily see an immediate use for this because the arc segments are buried so deep.. i think when it i try to make a useful dc (such as that fillet example i posted the other day -- which i'm thinking is possible now), i'll just have it make guide points and i'll draw the arcs/lines over them..
          dotdotdot
            It is the angle between the 2 radii at the 2 ends of the chord...
              jeff hammond
              Right. After reading your post a few times, I realized that I was looking at the whole thing wrong (way over thinking it πŸ˜„)
              Your post made me realize there's a right triangle (or 2) in there. Right triangles I can deal with ok.
              dotdotdot
