    Bended roof, how?
    8 Posts 4 Posters 504 Views 4 Watching
      joscha
      hello,
      I m stuck on the design of a paper board roof that is supposed to be slightly bended into a HP plane. so all the sides are straight but since they are not parallel the plane in between is bend. So what i need to do is pretty much taking a group (which is the roof divided in vertical paper structures) and move the edges of the roof into a non parallel plane.
      HOW????
      I tried it with shape bender but it bends the edges aswell. any one an idea? a plugin? help πŸ˜„
      best regards, joscha
        ExtrudeEdgesByRails ? where you make the four sides as divided edges > curves [use weld etc]...Capture.PNG
        • V Offline
          Vicspa
          Boy,...you can't get a quicker and better answer than that. πŸ‘
            joscha
            nice,thanks! can u also take a complete group because i already have the 80cm thick structure of the roof that is divided into a coffered ceiling. so can u take the group and bended onto that plane?
              The resultant mesh is a group.
              You need JointPushPull to add thickness to it...
              If it's to be coffered then perhaps EEbyLattice could do it for you in one step...
                joscha
                puh finnaly got it thanks:) took me a while.
                but how can i make the coffered ceiling with a XXXXX structure? right now its all /////
                u know what i mean?
                • jarynzlesaJ Offline
                  jarynzlesa
                  tiger at computer. thx for all your plugins πŸ‘ .
                  http://www.vizualizaceschodiste.mypage.cz/
                    joscha
                    We are good but your cryptic clues are not clear.
                    Can you attach images [or SKPs] of what you get and what you want ?
                    It might be that you actually need to do some work making this form and that plugins will only help you a certain distance along the road.
                    With a little more detail I sure we can advise you how to do this...
