    [Plugin] Grow
    45 Posts 19 Posters 71.5k Views 19 Watching
      Here's a new future-proofed update.
      http://sketchucation.com/forums/viewtopic.php?p=324331#p324331
      • H Offline
        huckrorick
        Hi Tig,
        I just tried your plugin. very cool. However, it seems like I can't get it to do what I want. I want to offset a component by a fixed amount (this works fine) and have each element be a fixed amount taller (e.g. 6"). I only seem to get a fixed increment with a scaling factor of 1.0 and then the increment in height is equal to the height of the component.
        Can I accomplish what I want with your plugin?
          Normally you can take any value on each axis, by move, by size, by rotation!
          • Y Offline
            YDAVIDI
            HELLO
            IT SEEM LIKE A GREAT PLUGIN BUT THE AXIS I CHOSE DOESNT WORK.. IT ALWAYS ROTATE IT AROUND SOME OTHER POINT..
            CAN YOU PLEASE HELP
            THANKS!
              Make sure that your axes are reset to the default model-axes [right-click on an axis and choose reset if available].
              It'd be sensible to locate the objects you want to 'grow' around the model's origin, then when prompted just snap to the origin [where the axes meet].
              The XYZ [RGB] axes are what's used by the tool.
              Also ensure that unit-snapping is OFF in Model Info > Units.
              • 3 / 3
