    [Plugin] Grow
    45 Posts 19 Posters 72.6k Views 19 Watching
      @nektares said:
      Hi TIG ๐Ÿ˜„ this looks like a very interesting plugin but when i try to use it i get this on the ruby console:
      for nil:NilClass>
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:339:in move' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:336:in each'
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:336:in move' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:554:in run'
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:86:in `onLButtonDown'
      ยฟAm i missing something?
      I suspect that you have some rogue script installed that is beyond this last fix... I'll look at an update... ๐Ÿ˜’
        Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=324331#p324331
        I hope that it finally addresses all of the issues cause by 3rd party rogue scripts that ill-advisedly overwrite base class/methods and/or with miscast observers for groups/selections...
        Sorry for today's confusion...
        The tool only failed for a few users who had this 3rd party script combo... BUT now ALL should work OK... ๐Ÿ˜•
        • N
          nektares
          Thanks a lot TIG ๐Ÿ˜„!!
          I found the guilty plugin, The problem was caused by SketchyPhysics3 i removed it and now my mirror plugin, my mshstick plugin and the grow plugin now work fine!
          Iยดm having a blast with your script, thank you!
          grow
            good job
            • I
              ivreich
              Instant Bugsplat
              HI TIG
              I downloaded the latest version of grow but I'm still having instant bugsplats. No error messages.
              I used a simple box, and don't have SketchyPhysics installed...
              Joel
                Joel
                If you have the Ruby Console open before you use it are there any messages ?
                Do you have DrivingDimensions, SunStudy, Matchbox, Podium installed - these can have similar issues as SketchyPhysica and break standard methods...
                Can you post the simple SKP that fails for you, with instructions on what you do to get a 'fail'...
                  joeyme
                  very nice
                    Here's a new future-proofed update.
                    http://sketchucation.com/forums/viewtopic.php?p=324331#p324331
                    • H
                      huckrorick
                      Hi Tig,
                      I just tried your plugin. very cool. However, it seems like I can't get it to do what I want. I want to offset a component by a fixed amount (this works fine) and have each element be a fixed amount taller (e.g. 6"). I only seem to get a fixed increment with a scaling factor of 1.0 and then the increment in height is equal to the height of the component.
                      Can I accomplish what I want with your plugin?
                        Normally you can take any value on each axis, by move, by size, by rotation!
                        • Y
                          YDAVIDI
                          HELLO
                          IT SEEM LIKE A GREAT PLUGIN BUT THE AXIS I CHOSE DOESNT WORK.. IT ALWAYS ROTATE IT AROUND SOME OTHER POINT..
                          CAN YOU PLEASE HELP
                          THANKS!
                            Make sure that your axes are reset to the default model-axes [right-click on an axis and choose reset if available].
                            It'd be sensible to locate the objects you want to 'grow' around the model's origin, then when prompted just snap to the origin [where the axes meet].
                            The XYZ [RGB] axes are what's used by the tool.
                            Also ensure that unit-snapping is OFF in Model Info > Units.
