    [Plugin] Grow
    45 Posts 19 Posters 71.9k Views 19 Watching
      Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=324331#p324331
      I hope that it finally addresses all of the issues cause by 3rd party rogue scripts that ill-advisedly overwrite base class/methods and/or with miscast observers for groups/selections...
      Sorry for today's confusion...
      The tool only failed for a few users who had this 3rd party script combo... BUT now ALL should work OK... ๐Ÿ˜•
      • N
        nektares
        Thanks a lot TIG ๐Ÿ˜„!!
        I found the guilty plugin, The problem was caused by SketchyPhysics3 i removed it and now my mirror plugin, my mshstick plugin and the grow plugin now work fine!
        Iยดm having a blast with your script, thank you!
        grow
          good job
          • I
            ivreich
            Instant Bugsplat
            HI TIG
            I downloaded the latest version of grow but I'm still having instant bugsplats. No error messages.
            I used a simple box, and don't have SketchyPhysics installed...
            Joel
              Joel
              If you have the Ruby Console open before you use it are there any messages ?
              Do you have DrivingDimensions, SunStudy, Matchbox, Podium installed - these can have similar issues as SketchyPhysica and break standard methods...
              Can you post the simple SKP that fails for you, with instructions on what you do to get a 'fail'...
                joeyme
                very nice
                  Here's a new future-proofed update.
                  http://sketchucation.com/forums/viewtopic.php?p=324331#p324331
                  • H
                    huckrorick
                    Hi Tig,
                    I just tried your plugin. very cool. However, it seems like I can't get it to do what I want. I want to offset a component by a fixed amount (this works fine) and have each element be a fixed amount taller (e.g. 6"). I only seem to get a fixed increment with a scaling factor of 1.0 and then the increment in height is equal to the height of the component.
                    Can I accomplish what I want with your plugin?
                      Normally you can take any value on each axis, by move, by size, by rotation!
                      • Y
                        YDAVIDI
                        HELLO
                        IT SEEM LIKE A GREAT PLUGIN BUT THE AXIS I CHOSE DOESNT WORK.. IT ALWAYS ROTATE IT AROUND SOME OTHER POINT..
                        CAN YOU PLEASE HELP
                        THANKS!
                          Make sure that your axes are reset to the default model-axes [right-click on an axis and choose reset if available].
                          It'd be sensible to locate the objects you want to 'grow' around the model's origin, then when prompted just snap to the origin [where the axes meet].
                          The XYZ [RGB] axes are what's used by the tool.
                          Also ensure that unit-snapping is OFF in Model Info > Units.
                          • 3 / 3
