    Axis nuisance
    12 Posts 7 Posters 876 Views 7 Watching
    • MarianM Offline
      Marian
      I'm having a problem with the axis flipping around. When I'm outside of a component/group the axis are in one way and when I enter to edit the component they flip around and it annoys the hell out of me as it can be very confusing at times plus when pasting something it appears aligned different from what you would expect.
      I hope I'm just stupid and overlooked some setting.
      Here's a picture to make my problem clearer, look carefully at the color of the axis. I hope somebody has the answer for this.
        dedmin
        On the first picture You see model axis but when You open the component You see its axes.
        • MarianM Offline
          Marian
          Yeah but the problem is that I didn't activate the internal axis, not intentionally anyway, it's a bit random. Do you know how it can be turned off or something?
          I knew you could use a different axis for each component but I never used the feature so I'm like a noob in this respect kind of sad to say that after using SU for around 5 years.
          • boofredlayB Offline
            boofredlay
            Marian, this is a new feature in SU8. The component will display the axis in which it was created while editing it.
            It is very useful when needing to draw "on axis" with the surrounding geometry.
            [flash=853,505:3w2gegxk]http://www.youtube.com/v/GoXR5vRU0mo&fs=1[/flash:3w2gegxk]
              dedmin
              You don't activate them - they are there. Every component/group has axes and you can change them, but cannot hide/disable. This is new in v.8.
              • MarianM Offline
                Marian
                Oh...I did not know that.
                http://animals.m-y-d-s.com/animal/donkey/i6.gif
                Thank you very much guys for the assistance. I can see the utility of such a feature but I wish it could be shut off.
                  Marian,
                  That's a fine picture of Festus Haggen's Ruth you've got there. πŸ˜‰
                  http://www.tvacres.com/images/mule_ruth_festus.jpg
                  • Wo3DanW Offline
                    Wo3Dan
                    @marian said:
                    ... I can see the utility of such a feature but I wish it could be shut off.
                    Right click on one of the axis in edit mode -> select 'Reset'.
                    This is a temporary solution that needs to be done each time you enter a group or component. But the advantages in SU8 top the advantages of how things worked in previous versions.
                    Better read about the same issue here:
                    http://forums.sketchucation.com/viewtopic.php?f=15&t=36481
                    Dave, you seem to remember all the old series.
                    Now that I see Festus I do remember his terrible voice. 😲
                      That's because I'm old. πŸ˜‰ I don't think his voice was so bad. πŸ˜†
                      • Jean LemireJ Offline
                        Jean Lemire
                        Hi folks.
                        Try Window Menu --> Model info --> Components. Uncheck the box labeled "Show component axes".
                        Just ideas.
                        • MarianM Offline
                          Marian
                          @dave r said:
                          Marian,
                          That's a fine picture of Festus Haggen's Ruth you've got there. πŸ˜‰]
                          I don't know that show but I do know Bonanaza πŸ˜„
                          Thanks that works, but I can't seem to always find the reset tab.
                          @jean lemire said:
                          Hi folks.
                          Just ideas.
                          It was unchecked, so it's not from there. 😞
                            @jean lemire said:
                            Hi folks.
                            Just ideas.
                            That's only to display component axes when you are outside the editing context. This new thing in v.8 is actually when the model axes are (temporarily) adjusted to the component axes when in editing mode.
                            Confused me a bit when it was new to me, too, but to be honest, it was very easy to get used to (and I like it this way)
