    Can't import any files :(
    4 Posts 3 Posters 358 Views 3 Watching
    • J
      jttunn
      Please help! I'm trying to import images thro file-import, but in box with choosin type of file there're - Sketch Up files(.skp)and ACAD files(.dwg *dxf) only. I was searching every where but found nothing(! Reinstallation gives no results!(Sorry! But I'm totally noob in SU and my English very poor(I'll be very happy to any advice!!!) Thanks a lot!
      • TIGT
        You need to select the 'type' of file to import - the available files then change depending on the file-type chosen.
        Note that the file-types have different 'options' which you should also consider/adjust when importing.Capture.PNG The types vary depending on the SUp version etc...
        • J
          jttunn
          the poin is that i there isn't other types in that dialog box. Only 2 types i have there- Sketch Up files(.skp)and ACAD files(.dwg *dxf).Only firs two from the list in the picture you've attached. That what i mean. I can't choose .jpg for example. bcaurse there is no this type of a files. I've got 7.1 PRO vershion of SU. I was thinkin that problem could be solved by remooving oficial russian language patch. But reinstalling to defaults gives no any changes in this problem. Once again sorry 4 my eanglish and thanks!!! 😄
          • K
            KarinaGM
            Not a solution but a work around. For importing images into the skp file you can drag/drop them
            **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
            -Benjamín Franklin.**
