[Plugin] Layer Tools (1.1.0)
Overview
A small utility I made to quickly hide layers by click on entities.Access
Tools > Hide Layer by PickFeatures
Hide Layer by Pick
Hides the layer of the picked entity.Requirements
- SketchUp 7 or newer - ( Other versions untested )
- TT_Lib2 (v2.0.0)
http://sketchucation.com/pluginstore?pln=tt_layer
Footprint
<Sketchup>/Plugins/
tt_layer.rb -
149 downloads and no thank you's? There are some really ungrateful bastards out there
Thanks Thom, I just needed something like this
(not yet tested)
If I click a composant, Layer of this component will be hidden? -
Thanks, Tom
I can see where this would be useful in certain circumstances. How often, for me, I am not sure.
Thanks, TT, it's a useful tool and I've used it several times.
(ungrateful bastard #127)
You must be some kind of mind-reader Thom!
Excellent tool, as always! You're so generous..I noticed a little thing: the layer taken into cosideration is only the one which contains directly the faces of the objects. It means that if you have 6 faces making up a glass box on "layer0" and a group holding them together on layer "glass", if you click on the group nothing happens, at least for me.
Could be useful to extend the turn-off-layer ability to groups and components too (if they're made of homogeneous sub-entities). What do you say?
That will make the tool very slow when interacting with groups/components of heavy meshes as it'd involve inspecting all related elements.
Yes...you're right... Think about some trees or cars!
Could have been useful, anyway
@bertier said:
not in the tools drop down menu ...
You screenshot shows the Plugins menu...
The tool is under the Tools menu - named "Hide Layer by Pick" -
but in the plugin folder ...any clue ?
EDIT :
yes it is !
sorry about that...
thanks!
This is a very useful tool! Thank you very much!
But there is no button on the toolbar panel. How to make a button? -
Sorry. This was repeat post
Big thx!
Is there something like "Put selected objects on a new layer and hide this Layer".
This is very handy...thank you for posting!
does this work with 2015?
Should do, yes.
I am not seeing the tool in the menus. Why does the icon appear without a blue 'book'?
With your input, this post could be even better ๐
Register LoginAdvertisement
