    Huge layout pdf exports
    layout
    8 Posts 5 Posters 3.2k Views 5 Watching
    • A
      arthur87
      I had a sketchup model of an office complex. It has lots of highrise buildings with heights varying from 15 -30 floors. I sent that to layout. But on exporting it as a pdf ...Layout stopped responding. I have Intel Core2Quad Processor with 4 GB RAM. Is there a tip to export pdfs from large models from layout.??
      • J
        JuanV.Soler
        Sometimes when the Export to PDF does not work properly in Layout 3
        I try to print the file instead of exporting it,
        if you have CutePDF writer installed as a printer option, it may work for you too.
        here is the link in case you dont have it.
        http://www.cutepdf.com/products/cutepdf/writer.asp
        • KrisidiousK
          Krisidious
          if they are in high detail they are absolutely massive... I tried to do a layout set the other day and it was a 300 meg pdf. freaking nuts.
          By: Kristoff Rand
          • AnssiA
            Anssi
            It seems to be the same with all 3D applications: PDF exports tend to be huge. For me the "Reduce file size" command in Adobe Acrobat (in Standard an Professional versions) has often proved very useful. I just tried for an example: I exported a 9-page Layout file that gave a 15-megabyte PDF, and Acrobat reduced that into 980K with no visible deterioration in quality. Archicad and Revit exports seem reduce even more.
            Anssi
            • A
              arthur87
              how much time did it take to export?? 😲
              • EdsonE
                Edson
                if you look around the internet you will find several ways to reduce the size of pdf files. I found a great way to reduce pdf files by 75% on mac.
                http://www.mahfuz.arq.br
                • KrisidiousK
                  Krisidious
                  not very long to export.... I would say 10 minutes tops.
                  By: Kristoff Rand
                  • KrisidiousK
                    Krisidious
                    I use PDF995 it installs as a printer port on your computer, so you just print as if you were plotting your plans on a printer. it prints out in a pdf file on your computer and the file sizes are very reasonable. this way I can skip the whole export thing. I use it in autocad as well.
                    http://www.pdf995.com/
                    By: Kristoff Rand
