    Modeling a bathtub:How do I get 2 different sections to meet
    4 Posts 4 Posters 765 Views 4 Watching
    • M
      make
      I am trying to model this Toto bathtub. I am puzzled as how to get the different section profiles to meet properly at the corners.
      Anyone have a suggestion?
      Much appreciated!!!
      Cheers,
      Wm
      The Sketchup file
      • numbthumbN
        numbthumb
        Fredo´s RoundCorner?
        http://forums.sketchucation.com/viewtopic.php?t=20485
        Comfortably numb...
        • TIGT
          Because it's a relatively simple shape and draw well in CAD you can easily edit the plan and two main cross-sections to add faces to the actual cross-section and use PushPull to make extrusions of them bigger than they need to be.
          Group each one.
          Arrange the groups so they correctly intersect and select geometry in one and use the Intersect tool to cut it withe the others.
          Repeat process until the forms all intersect fully.
          Explode all three into one group.
          Erase the unwanted parts and you should now have the required shape - you will need to do some tweaking of shapes etc but it's a good start...
          • StilTegS
            StilTeg
            First, always get rid of any symetrical pattern, all that is symetrical can be cut in 2 and reassembled later ...
            doing technical engineering on SketchUp ... without plugins
