    Help with posting images?
    9 Posts 5 Posters 558 Views 5 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Admin, I can no longer display a upload image, did you change the Forum defaults?Temp00.png
      • KrisidiousK Offline
        Krisidious
        hmmm...
        I think it is because it's a .PNG file...
        By: Kristoff Rand
          Here's a PNG test. I can see it anyway.
            honoluludesktop
            Hmmm...Solved, It's the size of the file. Attached is a 10% reduction of the one that failed.
              That's odd. What happens to make it indicate the file size is 11.86Kb in your first post? Or is it actual width that causes that?
                honoluludesktop
                Don't know. Does it matter? If I cannot preview the image, I rescale it anyway. Sigh!.... Maybe the cost of bandwidth is the reason. I can relate to that.:)
                  I've raised it before with Gaieus...
                  Some images just 'attach' rather that 'display' - if you have some known width limits etc it could help to track down the weird glitch...
                    honoluludesktop
                    SketchUcation is something like those "leading edge" applications that are fantastic in many ways, but are plagued with intermittent shortcomings, like my (ha, ha, leading edge) software.:)
                      Yes, I get that too sometimes. It indeed seems to be the file size (rather than resolution size). Save it as jpg and it will become larger - then it displays.
                      We should really close down one of these days and clean up this forum software. It has so many glitches!
