    VRImage from 1.49?
    renderpluginsextensions
    6 Posts 2 Posters 1.5k Views 2 Watching
    • focptF Offline
      focpt
      Has anybody successfully exported to vrimage? One I convert it to .exr it opens just as a black image.
      Is it necessary to save the irrdiance map first?
      I have SU8, vray 1.49, win 32 bit, 4 gb, 2.53 dual core. The scene is around 30 mb. I have tried taking out high poly geometry and rendering a small output with no luck.
      Any input is appreciated.
      • Nathan
        http://www.focalpointstudio.net
      SU8, VRay 1.49
      • jarynzlesaJ Offline
        jarynzlesa
        Das funktioniert. Ja gůt 👍 .
        http://software.asgvis.com/index.php?option=com_content&view=article&id=16;vfr-tutorial-a&catid=501;vfr-tutorials
        http://www.vizualizaceschodiste.mypage.cz/
        • focptF Offline
          focpt
          Yes, I have tried that step-by-step. First of all, that is for Rhino and some of the steps aren't options in 1.49 (eg. enable the "New Map mode" )
          However, I can follow it, but it results in a black image.
          • Nathan
          SU8, VRay 1.49
          • focptF Offline
            focpt
            I discovered that there is an option for a direct output to .exr from vray. I tried that and I got something better than all black, but the colors are washed out and there is a white line around the profile. Attached are some pictures.
            Ultimately, I'm trying to cut time out of a rendering I'm working on (11hrs for 5000px wide). Maybe this isn't a viable technique to help reduce rendering time.
            • Nathan
            SU8, VRay 1.49
              jarynzlesa
              open *.exr in photoshop. after you open *.exr, photoshop should ask you for adjusting the gamma.
              • focptF Offline
                focpt
                Adjusting the gamma makes the image quality better. However, that white line is still there. Thanks for the ideas.
                I'm not convinced vrimage is useful for me.
                • Nathan
                SU8, VRay 1.49
