    [Plugin] "folder" (Updated 15/02/2016)
    13 Posts 7 Posters 12.9k Views 7 Watching
      sahi
      The script is designed for quick access to designated folders.
      This plugin will import a file selected in the openpanel into Sketchup
      Description: The script consists of a two icons in a folder for each icon is assigned a path to the folder.
      1. Icon opens files SketchUp and memorizes the folder
      2. Icon imports files in SketchUp model and memorizes the folder
      3. Save model SketchUp 8
      Folder_v5.rbz
        How do i assign new destinations? Edit the .rb?
          sahi
          No
          Click on the icon, then select the desired folder, and all. The way the script will register itself
            Works great 👍
            • Dan RathbunD Offline
              Dan Rathbun
              This plugin will import a file selected in the openpanel into Sketchup (using the Ruby method model.import with show summary set to true.)
              Your first post should tell users this fact, Sahi.
              And.. (not so important,) you are using 32x32 pixel icons. Sketchup uses 16x16 (small) and 24x24 (large) sizes. Your icons will be very blurry when they are shrunk down.
              I'm not here much anymore.
                sahi
                Corrected the first post.
                  Ben Ritter
                  @sahi said:
                  No
                  What is meant by, "and all"?
                  • EarthMoverE Offline
                    EarthMover
                    I think he meant "and that's all". Meaning once you choose a folder it remembers the location.
                    Content Creator at Skapeup
                      Ben Ritter
                      It remembers the folder, but it does so for both folder 1 and folder 2. Once you assign a new folder for either one, it is assigned to both buttons.
                      Have you had success assigning each button with it's own folder?
                        sahi
                        Updated the script in the first message
                        Fixed
                          sahi
                          Updated the plug-in in the first message
                          • sadyoS Offline
                            sadyo
                            At last,... very long awaited update, Thanks sahi
                            • deaneauD Offline
                              deaneau
                              @sahi большо́е спаси́бо за плагины 😄 Many thanks for your plugins
                              no no im not from russia 😄
                              MADE, BORN AND LIVING IN BERLIN
                              Big Thank You to all Programmers
                              Some German words are so long that they have a perspective. M.Twain
