[Plugin] "folder" (Updated 15/02/2016)
The script is designed for quick access to designated folders.
This plugin will import a file selected in the openpanel into Sketchup
Description: The script consists of a two icons in a folder for each icon is assigned a path to the folder.
1. Icon opens files SketchUp and memorizes the folder
2. Icon imports files in SketchUp model and memorizes the folder
3. Save model SketchUp 8
How do i assign new destinations? Edit the .rb?
No
Click on the icon, then select the desired folder, and all. The way the script will register itself -
Works great
This plugin will import a file selected in the openpanel into Sketchup (using the Ruby method model.import with show summary set to true.)
Your first post should tell users this fact, Sahi.
And.. (not so important,) you are using 32x32 pixel icons. Sketchup uses 16x16 (small) and 24x24 (large) sizes. Your icons will be very blurry when they are shrunk down.
@sahi said:
No
Click on the icon, then select the desired folder, and all. The way the script will register itselfWhat is meant by, "and all"?
I think he meant "and that's all". Meaning once you choose a folder it remembers the location.
It remembers the folder, but it does so for both folder 1 and folder 2. Once you assign a new folder for either one, it is assigned to both buttons.
Have you had success assigning each button with it's own folder?
Updated the script in the first message
Fixed
- Icon opens files SketchUp
- Icon imports files in SketchUp model
Updated the plug-in in the first message
At last,... very long awaited update, Thanks sahi
@sahi большо́е спаси́бо за плагины
Many thanks for your pluginsno no im not from russia
