    Howto?? Extrude a design?
    7 Posts 5 Posters 443 Views 5 Watching
    • JoelM3DMJ Offline
      JoelM3DM
      I have a complex logo that has to be painted onto an organic shape (the side of a vehicle). I'm not sure how, but I think I did this once by push-pulling the logo and then intersecting with the shape. Is that the best way?
      And also, what's the trick to turning a complex b&w jpg into a form that I can extrude?
                Joel
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
      • ely862meE Offline
        ely862me
        Yes,that is the best way,intersecting.
        There is no such plugin that makes contours of logos unless they have transparent background and saved as png.
        If the logo is not too complicate u can trace over with the pencil or arc tools.
        Elisei (sketchupper)
        Come and See EliseiDesign
        • JoelM3DMJ Offline
          JoelM3DM
          Thanks Elisei!
          I can convert the graphic to a png with transparent background. What is the plugin for that?
          • mitcorbM Offline
            mitcorb
            Can you not convert jpg to png in Photoshop? Gimp?
            And thomthom did some work I believe on converting images to displacement maps?
            • ely862meE Offline
              ely862me
              It is called image trimmer and is part of this set of tools which u can find here
              http://forums.sketchucation.com/viewtopic.php?p=293677#p293677 .
              Remember the png must be very accurate otherwise will make creepy edges.
              If u want you can let me see what is it about and maybe to give some proper advice about how to apply the logo on the car.
              Cheers!
                mac1
                See if this may help http://www.youtube.com/aidanchopra#p/c/ED1EE89D47DB7EE5/2/HHsRRLCAOm8
                  Also read up on ImageTrimmer - it might do what you want semi-automatically.....
