    Need some help with complex curves
    5 Posts 3 Posters 459 Views 3 Watching
    • hellnbakH
      hellnbak
      I've run into something that is beyond my meager capabilities. I want to smoothly join the steering wheel column with the speedometer housing like in the photos. It's a lot of angles and curves and whatnot, and my efforts have been less than acceptable. I don't want somebody to do it for me, I just want some advice on how to best get it done right. I can provide more reference photos if needed, and I've attached the model file in case that would help. Any help would be much appreciated.
      Untitled.skp
      • ely862meE
        ely862me
        Maybe some follow me and scale would have make it too.
        a.skp
        Elisei (sketchupper)
        Come and See EliseiDesign
        • hellnbakH
          hellnbak
          Thanks for the input. But it still doesn't blend smoothly with the model, that's the part I'm having problems with.
          • ely862meE
            ely862me
            If you wan it to blend smoothly you must make it an entire piece from the ground up. .
              404 Not Found
              (forums.sketchucation.com)
              Coming soon....but ask Thomthom when?
