    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Hayrake Dining Table
    28 Posts 9 Posters 6.4k Views 9 Watching
      http://farm6.static.flickr.com/5256/5479721282_6cb18984ce_z.jpg
      http://farm6.static.flickr.com/5099/5479120639_b8bfe0f18b.jpg
      Done for my number one client. More here and
        You never fail to depress me!
        I meant impress
          The feeling is mutual, my friend. ๐Ÿ˜‰
          • mitcorbM Offline
            mitcorb
            I took a quick look at your site, and Mr. Pekovich's introduction video. That graceful end curve on the table top really enhances the design. I could see me really screwing up those router chamfers.
            Thanks for the image.
            • boofredlayB Offline
              boofredlay
              Great work Dave, I'll take two.
                Tim, those curves are indeed nice. I think you'd do fine making them using a template as was done for the original.
                Eric, Thank you. I'll get right on that order...after I get my list whittled down and get one of those made for us. ๐Ÿ˜„
                  bentlyj
                  Nice job Dave.
                  I spent a lot of time trying to do a stopped chamfer
                  with no success!!
                  I just saw your tutorial on Design, Click, Build.
                  I think I will have to give it another go when I get a chance.
                  Your a great teacher!
                  Thanks,
                  Bently
                  • Bryan KB Offline
                    Beautiful simplicity.
                    How DID you do those chamfers?
                      Thank you, Bently and Bryan.
                      Bryan, I described how I did those chamfers here. the description takes longer to read than it took to make them in SketchUp.
                      • Bryan KB Offline
                        Excellent. Thanks!
                          I decided to bang out a quick and dirty render in Kerkythea. I didn't spend much time on it and the background isn't anything to write home about but here it is.
                          http://farm6.static.flickr.com/5015/5484028856_0964d532de.jpg
                          • Bryan KB Offline
                            VERY nice.
                            • daleD Offline
                              dale
                              Dave
                              This has a decidedly shaker simplicity to it.
                              Is this a design you developed, or is it based on an historic piece?
                              I really like it, and you've done a great job on it.
                                Thank you Bryan and Dale.
                                Dale, I wish I could claim credit for the design but that belongs to Michael Pekovich at Fine Woodworking. He was used a hayrake table designed by Sidney Barnsley
                                http://www.artsandcraftsdesign.com/images/sidney_barnsley_hayrake_table.jpg
                                It's considered part of the Arts and Crafts movement.
                                • daleD Offline
                                  dale
                                  Thanks Dave.
                                  Interesting fellow Barnsley.
                                  What is it about Cotswald that spawns so much creativity?
                                    Dale, you're welcome. He is an interesting fellow for sure. I don't know enough about the Cotswolds but I wonder if it has traditionally been a place for the artists and craftspeople.
                                    MH, thanks. You could build it with no glue. The tenons are wedge or draw bored. The original was built with the planks joined with butterflies and no glue would be needed for them. The butterflies look like two dovetails put together in an hourglass shape. The way they were done for the original table, they pulled the planks together as they were driven home.
                                      So this morning I was experimenting with Photoshop Elements (it was free with my Wacom Intuous4) and I managed to get this:
                                      http://farm6.static.flickr.com/5011/5499650346_00ccb70d32.jpg
                                      I'm sure the way I did it was probably the hard way. I wonder if anyone would be kind enough to give me some pointers about the right way to get this sort of result. Solo suggested I look at a freeware app called Squirlz which I tried but I didn't like the results I got. I do appreciate the suggestion very much, though and I bet I can do some other interesting stuff with it.
                                      If someone would be interested in giving me some tips, I would be grateful. It could be done in a separate post or by PM if desired.
                                      Thank you.
                                        http://articles.sitepoint.com/article/photoshop-fade-layer-mask shows how to 'fade' an image with a layer mask
                                        You can make two scene tabs one with full rendered color and the other in white + lines and no shadows etc.
                                        Import them both with the line as an overlay [erase all of the white so you see the colored version below].
                                        Add the fade layer mask to 'vignette' the colored part as you have done...
                                          Thanks, TIG. I'll check out that link.
                                          • Bryan KB Offline
                                            I LIKE that effect.
                                            • 1 / 2
