    Reason why Sketchup 8 may crash
    29 Posts 7 Posters 3.7k Views 7 Watching
      @kachupp
      This tool requires a not inexpensive 3rd-party add-on to Windows to be usable...
      Can't it be done in a normal cmd/bat format ?
      • kachuppK Offline
        kachupp
        @tig said:
        @kachupp
        Hi TIG .. The functions I used in the script are available in the FREE TCC/LE "light" version
        @isdigit[] .. @regexist[] .. @regdelkey[] ..@regquery[]
          OK.
          That's not so bad.
          Might have been a good idea to explain that in the original post though πŸ˜’
          AND it's limited to 'home use'...
            Reading your code it doesn't seem to overcome the ever growing list of Toolbar entries which are made from unused entries as a new toolbar arrangement is saved and supersedes the current one. This is what slows SketchUp's startup as all of the entries are read - even those that are subsequently unused...
            For that you probably need to remove all toolbar entries with duplicate BarID values, but how do you decide which is the more current to retain? The highest ...BarN might work, but then because there are holes in the numbering do newly made ones with the same BarID fill the gaps to confuse the next use of this cleanup tool, or could you perhaps remake the lone BarID entry with the most recent values using oldest number [lowest] of BarN and erase the other higher numbered exact duplicate version ?
            This gets us into a terrible tangle as several entries seem to refer to one another, so it'd be all too easy to cross-thread the Registry ! Aaargh!
            • kachuppK Offline
              kachupp
              Hi TIG
              What I am finding is that Getting Started and Large Tool Sets are some of the duplicated BarID values you mentioned. SU doesn’t add the BarName value to its own making it a little more tedious to sort through manually. Its either visible or not 0/1
              Will look into more on the weekend
              This is what I got so far
              ToolbarsUser-Bar0 = Standard
              ToolbarsUser-Bar1 = Principal
              ToolbarsUser-Bar2 = Camera
              ToolbarsUser-Bar3 = Drawing
              ToolbarsUser-Bar4 = Modification
              ToolbarsUser-Bar5 = Construction
              ToolbarsUser-Bar6 = Solid Tools
              ToolbarsUser-Bar7 = Walkthrough
              ToolbarsUser-Bar8 = Styles
              ToolbarsUser-Bar9 = Views
              ToolbarsUser-Bar10=Sections
              ToolbarsUser-Bar11=Large Tool Set
              ToolbarsUser-Bar12=Google
              ToolbarsUser-Bar13=Getting Started
              ToolbarsUser-Bar14= UNKNOWN πŸ˜•
              ToolbarsUser-Bar15=Shadows
              ToolbarsUser-Bar16=Layers
              ToolbarsUser-Bar17=Measurements
              ToolbarsUser-Bar18= UNKNOWN πŸ˜•
              ToolbarsUser-Bar19= UNKNOWN πŸ˜•
              ToolbarsUser-Bar20= UNKNOWN πŸ˜•
              ToolbarsUser-Bar21= UNKNOWN πŸ˜• possible toggles for menu items
              Values after Bar21 are allocated to Plugins "BarName"
              These unknowns maybe Menu item toggles
              • kachuppK Offline
                kachupp
                My findings
                The ToolbarUserCustom-bars appear to be backups of ToolbarsUser keys changing only x & y pos if moved.
                The mess in the registry is made by users trying different plugins then adbondoning the plugins because it may not be what they are after these remanences have no way of cleaning them selfs up.
                • danielbowringD Offline
                  danielbowring
                  Absolute confirm on this - went from about a minute to launch to a second or two.
                  If you have python installed on your system, here's the script I used to remove the keys:
                  Usage: (all values have reasonable defaults, so just executing the script is fine)
                  $ clean_sketchup_reg.py -h
                  usage; clean_sketchup_reg.py [-h] [--path PATH] [--root ROOT]
                                               [--pattern PATTERN] [--verbose VERBOSE]
                  Sketchup Toolbar cleaner
                  optional arguments;
                    -h, --help         show this help message and exit
                    --path PATH        registry path
                    --root ROOT        root key
                    --pattern PATTERN  remove pattern
                    --verbose VERBOSE  verbosity
                  Code:
                  import _winreg as reg
                  import re
                  import sys
                  import argparse
                  def get_root_key(name);
                      try;
                          key = getattr(reg, name)
                          return key
                      except KeyError;
                          pass
                      raise ValueError('Root Key "%s" was not found' % name)
                  class Cleaner(object);
                      def __init__(self, root, path, pattern);
                          self.root = reg.ConnectRegistry(None, root)
                          self.set_path(path)
                          self.pattern = pattern
                      def set_path(self, path);
                          current = self.root
                          for p in path.split('/');
                              current = reg.OpenKey(current, p)
                          self.active_path = current
                      def clean(self, print_errors=False);
                          removed = 0
                          index = 0
                          while True;
                              try;
                                  key = reg.EnumKey(self.active_path, index)
                                  if self.pattern.match(key);
                                      try;
                                          reg.DeleteKey(self.active_path, key)
                                          removed += 1
                                      except WindowsError, e;
                                          index += 1
                                          if print_errors;
                                              print 'Failed to remove', key, ';', e.message
                                  else;
                                      index += 1
                                  return removed
                  if __name__ == '__main__';
                      parser = argparse.ArgumentParser(description='Sketchup Toolbar cleaner')
                      parser.add_argument('--path', type=str, help='registry path', default='Software/Google/Sketchup8')
                      parser.add_argument('--root', type=str, help='root key', default='HKEY_CURRENT_USER')
                      parser.add_argument('--pattern', type=str, help='remove pattern', default='^ToolbarsUser(Custom)?\-Bar\d+$')
                      parser.add_argument('--verbose', type=int, help='verbosity', default=1)
                      args = parser.parse_args(sys.argv[1;])
                      root = get_root_key(args.root)
                      path = args.path
                      try;
                          pattern = re.compile(args.pattern)
                      except Exception, e;
                          raise ValueError('Invalid pattern ; ' + e.message)
                      cleaner = Cleaner(root, path, pattern)
                      result = cleaner.clean(args.verbose >= 2)
                      if args.verbose >= 1;
                          print 'removed', result, 'keys'
                  Edit: Obligatory disclaimer, use at your own risk. I've tested it on my system and found no issues.
                  You can also use this script to clean webdialog entries:
                  clean_sketchup_reg.py --pattern "^WebDialog_.*$"
                    @kachupp said:
                    My findings
                    Some times dead entries multiply themselves due to SketchUp bug. It's not just uninstalled plugins.
                    • kachuppK Offline
                      kachupp
                      @tig said:
                      @kachupp
                      Yes I have found a way to do a .BAT / .CMD style way very simple indeed
                      It appears just by deleting two specific keys instead of all has the same effect as resetting the DAY one toolbar
                      option. Then re-instate the deleted keys restores the two deleted entries without duplicate errors. These re-instated
                      keys do need the correct data πŸ˜• not a problem will get to the bottom of it. "reg import whatever.reg" quick fix 😎
                      It shouldn't in theory matter if you have thousands of useless keynames but it does because of a possible bug that's known. TT said so, I take his word as the truth πŸ˜„ Love your work Thomas 😎
                      Will get back soon.. But the two keys we are interested in are ToolbarsUser-Summary / ToolbarsUserCustom-Summary
                      if they don't window each other its a problem. The data stored in those keys isn't hard to comprehend.
                      • 2 / 2
