    Saving in older versions by default
    7 Posts 6 Posters 10.7k Views 6 Watching
      cobb89
      is there a setting in sketchup to always save a file in an older format..for e.g. version 6 whenever we hit the save button so one doesn't always have to do File>save as>sketchup version 6
      • TIGT Online
        Not that we know of... 😞
          Didn't Jim make a utility for this?
          • TIGT Online
            Over to Jim - I suppose it would be possible on a PC using WinScripting ?
              You can always map the default shortcut (Ctrl+S) to File > Save as... and when you hit the button, the dialog pops up and you are then reminded to save in a previous version. I think Jim's solution was something similar, too, so there is no way to automate the saving in an earlier version.
              • PixeroP Offline
                Pixero
                http://forums.sketchucation.com/viewtopic.php?f=323&t=33441
                  ryo0ka
                  This is an old topic, but this is how I managed this in SketchUp 2017 Pro:
                  1. Download & install Jim's plugin from the link above.
                  2. Modify the file name format as you demand, in the plugin's preferences.
                  3. Re-assign Ctrl+S to the plugin's SaveAs command, in SketchUp's preferences.
                  Now you can save an old-version copy of your work by pressing Ctrl+S.
                  I needed this solution because I am exporting models from SketchUp to Unity3D, which only supports up to version 2015, whilst I am working in version 2017.
                  This is super easy of a workaround but I hope this made it clear for you πŸ˜„)))
