    Question: how to create a 3 way connected net
    5 Posts 2 Posters 461 Views 2 Watching
      laucity0513
      I would like to create a net with 3-ways connected tube (as shown in picture).
      I have tried follow me tool but it seems like it can't follow the line that branches out to two different directions.
      Can anyone tell me how to do that? Thanks!
        I assume you mean to give thickness the the 'edges' ?
        If all edges form faces [use a style with profiles 'on' so you can see what is unfaced or at an outer edge more easily] you can use RickW's Windowizer.rb or my LatticeMaker.rb etc to add 3D solid neatly joined 'frames' to the edges.
        These will be rectangular: if you want 'tubes' then find Didier Bur's 'line2cyl.rb' that will take selected edges [even unfaced ones] and add cylinders along them - but they won't join neatly...
        It depends what you are after........
          laucity0513
          Thanks for your quick reply. I modified the picture a little.
          As you can see, I want to make the edges become tubes. The faces should be deleted, which mean hollow eventually. Ultimately it will become like a piece of fishnet lying on the floor.
          I hope I have made myself clearer this time.
          Really appreciate for all the helps given. Thanks! πŸ˜„
            laucity0513
            Hi, just to add on. You may want to understand this model as a "chain-linked fence", just that it is 3 ways connected and the sizes of each hexagon is not in equal. Thanks!
              laucity0513
              I managed to create what I want! Thanks for telling me the plugin line2cyl.rb.
              πŸ˜„
