    Trees from above
    14 Posts 6 Posters 3.5k Views 6 Watching
    • EdsonE
      Edson
      does anyone know where I can find good images of trees from above (not top views) to use in aerial views? preferably free.
      http://www.mahfuz.arq.br
      • PixeroP
        Pixero
        I think you could come a long way with Google image search "aerial trees" then clone them in with Photoshop or Gimp.
        Make a brush in the shape of a tree from above and clone from a dense photo of a forest seen from above.
        If you want single aerial trees maybe some 3d trees from above?
        • EdsonE
          Edson
          thanks, jan. good tip. I will have a look at how brushes work in photoshop.
          • shuraS
            shura
            I think this is a good idea as well if you need single trees.
            Just downloaded the xFrog trees Gaieus recommended here.
            http://forums.sketchucation.com/viewtopic.php?f=40&t=34516
            Gave it a whirl with Podim V2 (recently upgraded, didn't test much) because it renders alpha transparency to PNG.
            Only a test without sun or materials.
            Could it be that what you are after Edson? Like this you could tweak view angle and sunlight as you need it.
            • GaieusG
              These are cool, Shure, IMO. Even such a "half above" tree can be made Face-me so for stills it should do the trick.
              Edson; just experiment a bit on what exact angle you need (and apply some decent shadow casting, dummy component inside)
              • EdsonE
                Edson
                thanks, alexander and csaba.
                I am not being able to import the xfrog trees into SU8. it crashes every time. is there any thing one must do in preparation for the import?
                • shuraS
                  shura
                  Are you trying to import OBJ? For me it didn't work, but with 3DS import it was hassle-free in SU 7.
                  (hm, now I am not shure if I checked import options for OBJ...)
                  Then use Frontface To Backface Thomthom's in UV-Toolkit to get the leaves texture on the backfaces.
                  I also smoothed trunk and branches and hid the edges of the leaves.
                  • EdsonE
                    Edson
                    3ds. it seemed to import it fast but SU crashed.
                    • shuraS
                      shura
                      Now OBJ import works, but it takes ages.... still running
                      Edit: after 2.5 hours no more progress at "processing line 205446 of 299348"
                      • GarethG
                        Gareth
                        Edson.....they are indeed quite heavy files....i found that it is wise to have absolutely nothing else running while you import a .obj file....and don't even minimise your window while it is working....
                        .....just wander off for a little while, have a coffee or whatever and let it do its work...!
                        • BurkhardB
                          Burkhard
                          Solo's garden pack contains some...if he is finished. May you ask him?
                          http://www.ia-plus.de
                          • GarethG
                            Gareth
                            If you are a Twilight Render user, you can download some skp files of some of the Xfrog trees
                            • EdsonE
                              Edson
                              I have them.
                              • EdsonE
                                Edson
                                still waiting for a mac version...
