    Trees from above
    14 Posts 6 Posters 3.6k Views 6 Watching
    • GaieusG
      These are cool, Shure, IMO. Even such a "half above" tree can be made Face-me so for stills it should do the trick.
      Edson; just experiment a bit on what exact angle you need (and apply some decent shadow casting, dummy component inside)
      • EdsonE
        Edson
        thanks, alexander and csaba.
        I am not being able to import the xfrog trees into SU8. it crashes every time. is there any thing one must do in preparation for the import?
        http://www.mahfuz.arq.br
        • shuraS
          shura
          Are you trying to import OBJ? For me it didn't work, but with 3DS import it was hassle-free in SU 7.
          (hm, now I am not shure if I checked import options for OBJ...)
          Then use Frontface To Backface Thomthom's in UV-Toolkit to get the leaves texture on the backfaces.
          I also smoothed trunk and branches and hid the edges of the leaves.
          • EdsonE
            Edson
            3ds. it seemed to import it fast but SU crashed.
            • shuraS
              shura
              Now OBJ import works, but it takes ages.... still running
              Edit: after 2.5 hours no more progress at "processing line 205446 of 299348"
              • GarethG
                Gareth
                Edson.....they are indeed quite heavy files....i found that it is wise to have absolutely nothing else running while you import a .obj file....and don't even minimise your window while it is working....
                .....just wander off for a little while, have a coffee or whatever and let it do its work...!
                • BurkhardB
                  Burkhard
                  Solo's garden pack contains some...if he is finished. May you ask him?
                  http://www.ia-plus.de
                  • GarethG
                    Gareth
                    If you are a Twilight Render user, you can download some skp files of some of the Xfrog trees
                    • EdsonE
                      Edson
                      I have them.
                      • EdsonE
                        Edson
                        still waiting for a mac version...
