    Trees from above
    14 Posts 6 Posters 3.4k Views 6 Watching
    • PixeroP Offline
      Pixero
      I think you could come a long way with Google image search "aerial trees" then clone them in with Photoshop or Gimp.
      Make a brush in the shape of a tree from above and clone from a dense photo of a forest seen from above.
      If you want single aerial trees maybe some 3d trees from above?
      • EdsonE Offline
        Edson
        thanks, jan. good tip. I will have a look at how brushes work in photoshop.
        http://www.mahfuz.arq.br
        • shuraS Offline
          shura
          I think this is a good idea as well if you need single trees.
          Just downloaded the xFrog trees Gaieus recommended here.
          http://forums.sketchucation.com/viewtopic.php?f=40&t=34516
          Gave it a whirl with Podim V2 (recently upgraded, didn't test much) because it renders alpha transparency to PNG.
          Only a test without sun or materials.
          Could it be that what you are after Edson? Like this you could tweak view angle and sunlight as you need it.
            These are cool, Shure, IMO. Even such a "half above" tree can be made Face-me so for stills it should do the trick.
            Edson; just experiment a bit on what exact angle you need (and apply some decent shadow casting, dummy component inside)
            • EdsonE Offline
              Edson
              thanks, alexander and csaba.
              I am not being able to import the xfrog trees into SU8. it crashes every time. is there any thing one must do in preparation for the import?
              • shuraS Offline
                shura
                Are you trying to import OBJ? For me it didn't work, but with 3DS import it was hassle-free in SU 7.
                (hm, now I am not shure if I checked import options for OBJ...)
                Then use Frontface To Backface Thomthom's in UV-Toolkit to get the leaves texture on the backfaces.
                I also smoothed trunk and branches and hid the edges of the leaves.
                • EdsonE Offline
                  Edson
                  3ds. it seemed to import it fast but SU crashed.
                  • shuraS Offline
                    shura
                    Now OBJ import works, but it takes ages.... still running
                    Edit: after 2.5 hours no more progress at "processing line 205446 of 299348"
                    • GarethG Offline
                      Gareth
                      Edson.....they are indeed quite heavy files....i found that it is wise to have absolutely nothing else running while you import a .obj file....and don't even minimise your window while it is working....
                      .....just wander off for a little while, have a coffee or whatever and let it do its work...!
                      • BurkhardB Offline
                        Burkhard
                        Solo's garden pack contains some...if he is finished. May you ask him?
                        http://www.ia-plus.de
                        • GarethG Offline
                          Gareth
                          If you are a Twilight Render user, you can download some skp files of some of the Xfrog trees
                          • EdsonE Offline
                            Edson
                            I have them.
                            • EdsonE Offline
                              Edson
                              still waiting for a mac version...
