    Trees from above
    14 Posts 6 Posters 3.3k Views 6 Watching
    • EdsonE Offline
      Edson
      does anyone know where I can find good images of trees from above (not top views) to use in aerial views? preferably free.
      http://www.mahfuz.arq.br
      • PixeroP Offline
        Pixero
        I think you could come a long way with Google image search "aerial trees" then clone them in with Photoshop or Gimp.
        Make a brush in the shape of a tree from above and clone from a dense photo of a forest seen from above.
        If you want single aerial trees maybe some 3d trees from above?
        • EdsonE Offline
          Edson
          thanks, jan. good tip. I will have a look at how brushes work in photoshop.
          • shuraS Offline
            shura
            I think this is a good idea as well if you need single trees.
            Just downloaded the xFrog trees Gaieus recommended here.
            http://forums.sketchucation.com/viewtopic.php?f=40&t=34516
            Gave it a whirl with Podim V2 (recently upgraded, didn't test much) because it renders alpha transparency to PNG.
            Only a test without sun or materials.
            Could it be that what you are after Edson? Like this you could tweak view angle and sunlight as you need it.
              These are cool, Shure, IMO. Even such a "half above" tree can be made Face-me so for stills it should do the trick.
              Edson; just experiment a bit on what exact angle you need (and apply some decent shadow casting, dummy component inside)
              • EdsonE Offline
                Edson
                thanks, alexander and csaba.
                I am not being able to import the xfrog trees into SU8. it crashes every time. is there any thing one must do in preparation for the import?
                • shuraS Offline
                  shura
                  Are you trying to import OBJ? For me it didn't work, but with 3DS import it was hassle-free in SU 7.
                  (hm, now I am not shure if I checked import options for OBJ...)
                  Then use Frontface To Backface Thomthom's in UV-Toolkit to get the leaves texture on the backfaces.
                  I also smoothed trunk and branches and hid the edges of the leaves.
                  • EdsonE Offline
                    Edson
                    3ds. it seemed to import it fast but SU crashed.
                    • shuraS Offline
                      shura
                      Now OBJ import works, but it takes ages.... still running
                      Edit: after 2.5 hours no more progress at "processing line 205446 of 299348"
                      • GarethG Offline
                        Gareth
                        Edson.....they are indeed quite heavy files....i found that it is wise to have absolutely nothing else running while you import a .obj file....and don't even minimise your window while it is working....
                        .....just wander off for a little while, have a coffee or whatever and let it do its work...!
                        • BurkhardB Offline
                          Burkhard
                          Solo's garden pack contains some...if he is finished. May you ask him?
                          http://www.ia-plus.de
                          • GarethG Offline
                            Gareth
                            If you are a Twilight Render user, you can download some skp files of some of the Xfrog trees
                            • EdsonE Offline
                              Edson
                              I have them.
                              • EdsonE Offline
                                Edson
                                still waiting for a mac version...
