    Cutting Panel lines in an object?
    15 Posts 4 Posters 2.2k Views 4 Watching
    • L
      liam887
      Right so I have been working on this model for the past 13 months, those of you who frequent the gallery section may have seen it coming to shape over that time.
      I have finished the basic shapes at last and now its time for the details. I want to cut panel lines in the main body (see attached reference image) instead of just adding them via a texture.
      Now its pretty tricky I can do it already using intersection tools but it is incredibly painstaking and such a slow way. I wondered if any of you sketchup geniuses have a way or can figure one out how to cut panel lines into the mesh. They dont have to very deep of course just a tiny gap between two welded plates.
      I have included part of the model for anybody to try with so good luck and hopefully somebody can figure out a most rtime effective method!
      Ref image for panel lines
      sketchup mesh file
      VISIT MY ONLINE GALLERY
      • jason_marantoJ
        jason_maranto
        I would also be very interested in this for a project I'm working on.
        Best,
        Jason.
          Whaat's Zorro Tool and Fredo's offset on surface come to mind.
          • L
            liam887
            I have offset on surface, I understand on principal how this would work but I cant do it with that tool, ill look into whatts zorro tool is it free, what does it do?
              slices lines , it's also in SDS if you have that?
              • L
                liam887
                Yeah I cant get it to cut in a nice neat line however it just gets a but messy on the geometry I think I need a lot more practice. I think maybe if the geo was sub divided again but its already pretty heavy as it is I would rather not? Ill keep trying with sub D see what I can come up with
                • L
                  liam887
                  Hi Liam
                  I know Jacques did it this way with Black Hawk, by lining the image up with the model drawing over the various panel sections, and then push pulling and then intersecting and erase unecessary geometry. Time consuming but pretty accurate. Just ideas as Jean would say πŸ˜‰ Black Hawk/
                  Thanks James but yeah its the method I already use and it takes forever! but I was wondering if there was a better way?
                    I'd break that fuselage up into chunks. That way you focus on one area at a time and pay more attention.
                    • jason_marantoJ
                      jason_maranto
                      If I was more savvy with Ruby I'd be trying to find a way to automate this from the lines... there's a bunch of scripts that are halfway there but none that I know of that get the job done.
                      Maybe we should create a request thread in the Plugin forum?
                      Best,
                      Jason.
                      • GaieusG
                        I think there would be easy ways with Fredo's plugins. Here I used Offset on surface then Joint PushPull to make a quick groove.
                        Untitled.skp
                        • L
                          liam887
                          Yeah I think this method is the winner so far! And yes Rich I do break the model up into many many different parts just to concentrate on each one I just put a basic mesh of the aircraft hull up for people to experiment with if they wanted.
                          • GaieusG
                            Certainly you'll have scale issues with tiny edges but I guess that won't cause a real problem.
                              i thought so but mentioned anyway. My pay more attention wasn't a remark more that segmenting geometry prevents me from drifting around tweaking here and there but eventfully achieving little.
                              It's a great looking mesh. One suggestion, download Tgi3d 30 trial and run 'upsample' on it. I did it and it rocked! Smooth and silky
                              • L
                                liam887
                                Oh yeah I know you wernt, haah if you could see the folder for this model your eyes would pop I probably have about 30-40 files each a different part of the helicopter, some are just small window wipers while others will be the optics package at the front etc, they only ever really come together when I need to do a render or get a general look. I also have two 'MASTER files' with all the components in different layers but my computer doesn't like that very much!
                                Ill look at Tgi3D in abit, does it come for MAC as im PC'less for the foreseeable future, I was devastated I went to get the trial of Luminon last night and its PC only it seems 😞
                                What is the purpose of un-sample is that just smoothing it out? what format does it use to go between SU and Tgi?
                                  you know when you smooth geometry with SDS and the size of your mesh scales down slighly? Tgi's 'up-sample' uses a fancy algorithm to smooth but keep things to size. There are other features that are pretty good but that's another time...
