    Problems doing a curve
    26 Posts 5 Posters 3.4k Views 5 Watching
    • TIGT
      @gumleguf said:
      Tig > Tried following your instructions and ended up with this. It looks correct except that when I use EEbyVector to extrude it backwards by 50mm my model gets "sliced up". I finished and also pasted the back to it and reversed it, but when smoothing the model the "slices" remains:
      [attachment=1:1bxp6nwa]<!-- ia1 -->gbl324234.JPG<!-- ia1 -->[/attachment:1bxp6nwa]
      [attachment=0:1bxp6nwa]<!-- ia0 -->JamoR909_clone_6_EEbyVector_1.skp<!-- ia0 -->[/attachment:1bxp6nwa]
      NOT quite the expected result... but not irredeemable...
      Select a face with the correct orientation and right-click 'Orient' to get them all facing the same way... then select all and Smooth till it looks like you want...
      • G
        Gumleguf
        TIG > Am I not following your instructions?
        I tried selecting a face, right-clicked and selected "Orient Faces", but it seems to me that it only made some other faces reverse?
        • TIGT
          I think I have it!
          You are making internal faces so can never successfully get orient faces to work as there are always some wrong!
          I think this is because you are extruding ALL Edges as you have View > Hidden Geometry ON and are working on the Smoothed ones as well.
          Switch View > Hidden Geometry OFF, then Select the Surface and its Edges [then Shift+Ctrl to deselect the Surface]...
          EEbyVector on the Edges back 50mm.
          At that point you shouls have all of the 'sides' made without a 'back'.
          Copy the front as the back as explained before and reverse it...
          πŸ€“
          • G
            Gumleguf
            I think you're right.
            Does this look correct (I think it does, but what do I know... πŸ˜‰ )?
            JamoR909_clone_6_EEbyVector_3.skp
            • TIGT
              Good!
              Now all you need to do is select the front Surface, right-click and Orient - all faces will be correct.
              To 'smooth' the edges you don't want around the top edge, Select all [treble-click surface] and right-click Smooth...
              Done πŸ˜„
              • G
                Gumleguf
                This is too cool.
                Thanks all. You are the best.
                • 2 / 2
