    Tgi3d SU Smart Texturing UV Unwrapping
    22 Posts 9 Posters 3.6k Views 9 Watching
    • Rich O BrienR Online
      UV Mapping in SU solved?
      http://www.tgi3d.com/index.php?Page=Amorph&VideoID=17983944&field=content10
      Verdict?
      • K Offline
        Khai
        not for me at that price.... cuddles his Uvmapper Pro
        • soloS Offline
          solo
          View locking (patent pending) is a central feature of Tgi3D SU
          What!? patenting code for SU?
          Hmmm, I need to see some organic shapes, more complex than those examples before even considering it.
          http://www.solos-art.com
          • jason_marantoJ Offline
            jason_maranto
            They do have a free version -- On their UV unwrap -- I like it, but there are certainly many instances where a more comprehensive solution is needed.
            It is an amazing plugin if you spend lots of time modelling from photos -- in a way it's like Building Maker on steroids... but probably the killer feature for me is the "cross section" tool. Their "skin" function is also pretty nice.
            Best,
            Jason.
            • FrederikF Offline
              Frederik
              Wonder if they really can do this...??
              Not sure I like this and I sure don't like their prices...!!
              Cheers
              Kim Frederik
                Price is a stumbling block for me too! But how much time would a tool of this flexibility save?
                • FrederikF Offline
                  Frederik
                  I've been using SU for about 4+ years now and I must admit that it's very rare that I've needed some special tools for UV-mapping...
                  Whaats UVTools v0.1 have helped me accomplish most of what have been needed...
                  I acknowledge that price isn't everything and if I believe it will save me enough time (= money) then I'd happily pay...
                  In this case I really doubt it...
                  For me such a tool should be priced between 20,00-50,00 USD - max...
                  What I don't like is the line regarding the pending patent...
                  (without wanting to draw any parallel, it somehow reminds me of the patent on the shadow thing in SU, which means that the clipping-bug when shadows are turned on, can't be solved...)
                  Cheers
                  Kim Frederik
                  • StinkieS Offline
                    Stinkie
                    Hm, I find this plugin a tad pricey too. Besides, Whaat's UVTools 0.2 Pro works great.
                    • KrisidiousK Offline
                      Krisidious
                      I want it... I just can't afford it.
                      By: Kristoff Rand
                        Here's some quick tests....
                        Curved surface painted normally
                        Curved Surface painted using Projected Texture
                        Curved Surface after using 'Create texture' in TGI3d
                        UV Map in Image Editor
                        Here's the file to take a look...
                        TGI3d_Example_1.skp
                        Another example with a more organic shape...
                        Here's the file...
                        TGI3d_Example_2.skp
                        • StinkieS Offline
                          Stinkie
                          Looks good. I oughta try the demo. Here's my try with Whaat's plugin.
                            What app you using for the mapping? I liked UV Tool Pro but couldn't get to grip with Roagkill for organic shapes.
                            They're identical BTW πŸ‘
                              Krisidious
                              wow... that's pretty sweet...
                              By: Kristoff Rand
                                Get the 30 day trial, you'll see why it's worth the investment
                                • StinkieS Offline
                                  Stinkie
                                  I used Modo 401 (demo). Got this for christmas: http://source3d.net/martinkrol.htm. Interesting stuff!
                                    And this is with ThomThom's UV Toolkit 2 (a sandbox mesh distorted with his Vertex Edit plugin but can be anything...)
                                    UV-map-test.skp
                                    • StinkieS Offline
                                      Stinkie
                                      What does that one do, keep the UV's as the model is being distorted?
                                        Why are you modelling butts? Thought you modelled things from the past not thongs at the rear!
                                          @stinkie
                                          http://forums.sketchucation.com/viewtopic.php?t=18992
                                          Checkout his videos
                                          • StinkieS Offline
                                            Stinkie
                                            Thanks, will do.
                                            Edit: sweet!
                                            • 1 / 2
