    Tgi3d SU Smart Texturing UV Unwrapping
    22 Posts 9 Posters 3.6k Views 9 Watching
    • jason_marantoJ Offline
      jason_maranto
      They do have a free version -- On their UV unwrap -- I like it, but there are certainly many instances where a more comprehensive solution is needed.
      It is an amazing plugin if you spend lots of time modelling from photos -- in a way it's like Building Maker on steroids... but probably the killer feature for me is the "cross section" tool. Their "skin" function is also pretty nice.
      Best,
      Jason.
      • FrederikF Offline
        Frederik
        @solo said:
        What!? patenting code for SU?
        Wonder if they really can do this...??
        Not sure I like this and I sure don't like their prices...!!
        Cheers
        Kim Frederik
        • Rich O BrienR Online
          Price is a stumbling block for me too! But how much time would a tool of this flexibility save?
          • FrederikF Offline
            Frederik
            I've been using SU for about 4+ years now and I must admit that it's very rare that I've needed some special tools for UV-mapping...
            Whaats UVTools v0.1 have helped me accomplish most of what have been needed...
            I acknowledge that price isn't everything and if I believe it will save me enough time (= money) then I'd happily pay...
            In this case I really doubt it...
            For me such a tool should be priced between 20,00-50,00 USD - max...
            What I don't like is the line regarding the pending patent...
            (without wanting to draw any parallel, it somehow reminds me of the patent on the shadow thing in SU, which means that the clipping-bug when shadows are turned on, can't be solved...)
            Cheers
            Kim Frederik
            • StinkieS Offline
              Stinkie
              Hm, I find this plugin a tad pricey too. Besides, Whaat's UVTools 0.2 Pro works great.
              • KrisidiousK Offline
                Krisidious
                I want it... I just can't afford it.
                By: Kristoff Rand
                  Here's some quick tests....
                  Curved surface painted normally
                  Curved Surface painted using Projected Texture
                  Curved Surface after using 'Create texture' in TGI3d
                  UV Map in Image Editor
                  Here's the file to take a look...
                  TGI3d_Example_1.skp
                  Another example with a more organic shape...
                  Here's the file...
                  TGI3d_Example_2.skp
                  • StinkieS Offline
                    Stinkie
                    Looks good. I oughta try the demo. Here's my try with Whaat's plugin.
                      What app you using for the mapping? I liked UV Tool Pro but couldn't get to grip with Roagkill for organic shapes.
                      They're identical BTW πŸ‘
                        Krisidious
                        wow... that's pretty sweet...
                        By: Kristoff Rand
                          Get the 30 day trial, you'll see why it's worth the investment
                          • StinkieS Offline
                            Stinkie
                            I used Modo 401 (demo). Got this for christmas: http://source3d.net/martinkrol.htm. Interesting stuff!
                              And this is with ThomThom's UV Toolkit 2 (a sandbox mesh distorted with his Vertex Edit plugin but can be anything...)
                              UV-map-test.skp
                              • StinkieS Offline
                                Stinkie
                                What does that one do, keep the UV's as the model is being distorted?
                                  Why are you modelling butts? Thought you modelled things from the past not thongs at the rear!
                                    @stinkie
                                    http://forums.sketchucation.com/viewtopic.php?t=18992
                                    Checkout his videos
                                    • StinkieS Offline
                                      Stinkie
                                      Thanks, will do.
                                      Edit: sweet!
                                        Yes, exactly. Top class plugin, could easily sell for like $ 20 when finished.
                                        Well, this was just for the sake of the UV's distorted and even scaled.
                                        But is your butt chequered that this was the first thing that came to your mind?
                                        πŸ˜„
                                        • Mike LuceyM Offline
                                          Mike Lucey
                                          Rich has a 'one track' mind πŸ˜’
