    Tgi3d SU Smart Texturing UV Unwrapping
    22 Posts 9 Posters 4.0k Views 9 Watching
    • KrisidiousK
      Krisidious
      I want it... I just can't afford it.
      By: Kristoff Rand
        Here's some quick tests....
        Curved surface painted normally
        Curved Surface painted using Projected Texture
        Curved Surface after using 'Create texture' in TGI3d
        UV Map in Image Editor
        Here's the file to take a look...
        TGI3d_Example_1.skp
        Another example with a more organic shape...
        Here's the file...
        TGI3d_Example_2.skp
        • StinkieS
          Stinkie
          Looks good. I oughta try the demo. Here's my try with Whaat's plugin.
            What app you using for the mapping? I liked UV Tool Pro but couldn't get to grip with Roagkill for organic shapes.
            They're identical BTW πŸ‘
            • KrisidiousK
              Krisidious
              wow... that's pretty sweet...
              By: Kristoff Rand
                Get the 30 day trial, you'll see why it's worth the investment
                • StinkieS
                  Stinkie
                  I used Modo 401 (demo). Got this for christmas: http://source3d.net/martinkrol.htm. Interesting stuff!
                  • GaieusG
                    And this is with ThomThom's UV Toolkit 2 (a sandbox mesh distorted with his Vertex Edit plugin but can be anything...)
                    UV-map-test.skp
                    • StinkieS
                      Stinkie
                      What does that one do, keep the UV's as the model is being distorted?
                        Why are you modelling butts? Thought you modelled things from the past not thongs at the rear!
                          @stinkie
                          404 Not Found
                          (forums.sketchucation.com)
                          Checkout his videos
                          • StinkieS
                            Stinkie
                            Thanks, will do.
                            Edit: sweet!
                            • GaieusG
                              Yes, exactly. Top class plugin, could easily sell for like $ 20 when finished.
                              Well, this was just for the sake of the UV's distorted and even scaled.
                              But is your butt chequered that this was the first thing that came to your mind?
                              πŸ˜„
                              • Mike LuceyM
                                Mike Lucey
                                Rich has a 'one track' mind πŸ˜’
