    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 335.1k Views 89 Watching
    • Didier BurD Offline
      Didier Bur
      instead of the input box for 'shape' I get the box as shown for 'vertices of faces
      @nickchun: this happens when the selection isn't empty before launching the tool.That's normal. If you read the doc you will notice that ๐Ÿ˜‰
      PLEASE READ THE DOC FOLKS ! ๐ŸŽ‰ ,
      DB
      • N Offline
        nickchun
        Didier, sorry, I didn't pick up on that in the manual. Components need to be placed in model outside of the selection right? Works fine. Thanks very much
        • OxerO Offline
          Oxer
          Thanks for update the plugin, i would like translate the plugin to spanish language, is this possible?
          http://www.oxervision.blogspot.com/
            Aldob
            It does bugsplat ?[/quote]
            It does nothing ๐Ÿ˜ž just closing SU down. Tested on SU 8.0 Works OK. But I have 7.1 Pro only. I guess some of ruby previously downloaded dcause that... But don't know which of them. Some of other commands from LSS tools and Tools on surface cause Closing down as well. They used to work well.
            Regards,
              Didier Bur
              Weird.
              There shouldn't be any conflict with another plugin because all is wrapped in a Ruby Module, and there are also no redefinition of standard methods or classes. A workaround would be to empty your Plugins folder except compoSpray, see if it works, and then add other scripts one by one and check when it makes SU close.
              Hope this helps,
              DB
                Didier Bur
                @nickchun:
                Components must have been imported in your model (you can see such components when clicking on the "house" icon of the components windows) prior to using the tool, otherwise they won't appear in the dropdown lists.
                When you select faces before launching the tool, the shapes dropdown list is replaced by 2 options: insert a component at each vertex of each selected face, or use the selected faces as the area to spray on.
                DB
                • simon le bonS Offline
                  simon le bon
                  Hi Didier
                  Sorry to come back with a new problem!
                  (It seems that I'm the only one to encounter this : )
                  Su6 and Su7 , I can't make any slider activ โ“ ๐Ÿ˜•
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thDBCompSpray14c.jpg
                  any suggestion?
                  simon
                  • Bob JamesB Offline
                    Bob James
                    I created a flat inclined plane, centered it at the origin, and put a yucca bush on it.
                    Under "Spray" I had two choices as expected:
                    Selected Faces
                    Vertices of Faces
                    I clicked on the plane, chose my yucca plant and selected "Selected Faces", then pressed "Spray"
                    Nothing happens.
                      Didier Bur
                      @bob james:
                      Bug found ! ๐Ÿ˜ณ
                      Will fix that asap
                      DB
                        hello
                        Same problem than Simon for the cursors in V6 : they don't move ๐Ÿ˜ข
                        But I have also a more difficult problem! ๐Ÿ˜ฎ
                        I can't see the total dialog box!!! and it can't be resized! ๐Ÿ˜’
                        • FrederikF Offline
                          Frederik
                          Haven't had any chance to play with this... ๐Ÿ˜
                          But the bug I reported previously is identical to what Bob James have reported above...
                          @didier bur said:
                          Bug found ! ๐Ÿ˜ณ
                          Will fix that asap
                          Cheers
                          Kim Frederik
                            Didier Bur
                            @Pilou: what a bunch of toolbars you have there !
                            compoSpray dialog box is 900 pixels (height) without scrollbars, that's right.
                            Isn't your screen more than 900 in height ?
                            DB
                            • TIGT Online
                              Yes but
                              I have my screen 1024*768 !!! ๐Ÿ˜’ (15 inch)
                              You have some free lines empty in your dialog box ๐Ÿ˜‰
                              How do you see everything at such a small size?2349098787_2cd660c18c.jpg ๐Ÿ˜ฒ ๐Ÿ˜‰
                                I have hidden some many other! ๐Ÿ’š
                                Yes but
                                I have my screen 1024*768 !!! ๐Ÿ˜’ (15 inch) so ๐Ÿ˜ฎ
                                  Yes but
                                  1024x768 screen with IE6 and SU6? ๐Ÿ˜ฒ
                                    Most time with Firefox, Opera... but also IE6 rarely ๐Ÿค“
                                    Why? That is forbidden? ๐Ÿ’š
                                    I have no case where I can't see a Su Project! ๐Ÿ˜Ž
                                    (saved in SU6 of course)
                                    Scrolling and zoom are my friends ๐Ÿ˜„
                                      But also IE6 rarely ๐Ÿค“
                                      Internet Explorer 6 - yes - it's forbidden. ๐Ÿ˜‰
                                      Webdialogs under Windows makes use of the Internet Explorer installed on the computer. So Webdialog issues with IE6 is quite probable to occur.
                                      You had problems with Vertex Tools's dialogs due to that, didn't you?
                                        I make some mouse scroll (if possible ๐Ÿ’š ) and zoom when necessary ๐Ÿ˜‰
                                        Generally is some sufficient ๐Ÿ˜Ž
                                          yes, so in this extrem case I take an another computer, but only for the modern plugins like yours โ˜€
                                          • F Offline
                                            fjb80
                                            Hi Again,
                                            Is there any way to get this plugin working for me? As you can see I've got a lot of trees, so it'd be great to avoid doing this manually again in the future.
                                            Thanks for all your help so far.
                                            Below is ThomThom's assessment of the issue.
                                            Fraser
                                            @thomthom said:
                                            @didier bur said:
                                            Does this not work on a Mac the same way than on a PC ??
                                            As you see in his error report, the plugin is trying to look for the file at:
                                            /Users/Fraser/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/CompoSpray
                                            while the plugin itself is located under:
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/compoSprayToolbar.rb:14
                                            OSX has a system Library folder and a User Library folder that looks very similar, and some users end up adding plugins to User Library. And I think Podium installs there.
                                            And then you can get issues with Sketchup.find_support_file
                                            The best way to determine the base path of your supporting folders are:
                                            File.dirname(__FILE__)
                                            In your case it'd be:
                                            @path_cs = File.dirname(__FILE__) + "/CompoSpray/"
                                            However, that won't work in .rbs files.
                                            In Vertex Tools I made the uncrypted loader, which was a regular .rb file, determine the paths and assign it to constants which the .rbs files could use.
                                            I've never had any path issues that way, and the plugins can be installed anywhere on the system. (if the user prefers to install in a custom location.)
                                            • 13
                                            • 14
                                            • 3 / 14
