    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 379.5k Views 89 Watching
      Aldob
      It does bugsplat ?[/quote]
      It does nothing ๐Ÿ˜ž just closing SU down. Tested on SU 8.0 Works OK. But I have 7.1 Pro only. I guess some of ruby previously downloaded dcause that... But don't know which of them. Some of other commands from LSS tools and Tools on surface cause Closing down as well. They used to work well.
      Regards,
      • Didier BurD
        Didier Bur
        Weird.
        There shouldn't be any conflict with another plugin because all is wrapped in a Ruby Module, and there are also no redefinition of standard methods or classes. A workaround would be to empty your Plugins folder except compoSpray, see if it works, and then add other scripts one by one and check when it makes SU close.
        Hope this helps,
        DB
        • Didier BurD
          Didier Bur
          @nickchun:
          Components need to be placed in model outside of the selection right?
          Components must have been imported in your model (you can see such components when clicking on the "house" icon of the components windows) prior to using the tool, otherwise they won't appear in the dropdown lists.
          When you select faces before launching the tool, the shapes dropdown list is replaced by 2 options: insert a component at each vertex of each selected face, or use the selected faces as the area to spray on.
          DB
          • simon le bonS
            simon le bon
            Hi Didier
            Sorry to come back with a new problem!
            (It seems that I'm the only one to encounter this : )
            Su6 and Su7 , I can't make any slider activ โ“ ๐Ÿ˜•
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thDBCompSpray14c.jpg
            any suggestion?
            simon
            • Bob JamesB
              Bob James
              I created a flat inclined plane, centered it at the origin, and put a yucca bush on it.
              Under "Spray" I had two choices as expected:
              Selected Faces
              Vertices of Faces
              I clicked on the plane, chose my yucca plant and selected "Selected Faces", then pressed "Spray"
              Nothing happens.
              • Didier BurD
                Didier Bur
                @bob james:
                Bug found ! ๐Ÿ˜ณ
                Will fix that asap
                DB
                  hello
                  Same problem than Simon for the cursors in V6 : they don't move ๐Ÿ˜ข
                  But I have also a more difficult problem! ๐Ÿ˜ฎ
                  I can't see the total dialog box!!! and it can't be resized! ๐Ÿ˜’
                  • FrederikF
                    Frederik
                    Haven't had any chance to play with this... ๐Ÿ˜
                    But the bug I reported previously is identical to what Bob James have reported above...
                    @didier bur said:
                    Bug found ! ๐Ÿ˜ณ
                    Will fix that asap
                    Cheers
                    Kim Frederik
                    • Didier BurD
                      Didier Bur
                      @Pilou: what a bunch of toolbars you have there !
                      compoSpray dialog box is 900 pixels (height) without scrollbars, that's right.
                      Isn't your screen more than 900 in height ?
                      DB
                        Yes but
                        I have my screen 1024*768 !!! ๐Ÿ˜’ (15 inch)
                        You have some free lines empty in your dialog box ๐Ÿ˜‰
                        How do you see everything at such a small size?2349098787_2cd660c18c.jpg ๐Ÿ˜ฒ ๐Ÿ˜‰
                          I have hidden some many other! ๐Ÿ’š
                          Yes but
                          I have my screen 1024*768 !!! ๐Ÿ˜’ (15 inch) so ๐Ÿ˜ฎ
                            Yes but
                            1024x768 screen with IE6 and SU6? ๐Ÿ˜ฒ
                              Most time with Firefox, Opera... but also IE6 rarely ๐Ÿค“
                              Why? That is forbidden? ๐Ÿ’š
                              I have no case where I can't see a Su Project! ๐Ÿ˜Ž
                              (saved in SU6 of course)
                              Scrolling and zoom are my friends ๐Ÿ˜„
                                But also IE6 rarely ๐Ÿค“
                                Internet Explorer 6 - yes - it's forbidden. ๐Ÿ˜‰
                                Webdialogs under Windows makes use of the Internet Explorer installed on the computer. So Webdialog issues with IE6 is quite probable to occur.
                                You had problems with Vertex Tools's dialogs due to that, didn't you?
                                  I make some mouse scroll (if possible ๐Ÿ’š ) and zoom when necessary ๐Ÿ˜‰
                                  Generally is some sufficient ๐Ÿ˜Ž
                                    yes, so in this extrem case I take an another computer, but only for the modern plugins like yours โ˜€
                                    • F
                                      fjb80
                                      Hi Again,
                                      Is there any way to get this plugin working for me? As you can see I've got a lot of trees, so it'd be great to avoid doing this manually again in the future.
                                      Thanks for all your help so far.
                                      Below is ThomThom's assessment of the issue.
                                      Fraser
                                      @thomthom said:
                                      @didier bur said:
                                      Does this not work on a Mac the same way than on a PC ??
                                      As you see in his error report, the plugin is trying to look for the file at:
                                      /Users/Fraser/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/CompoSpray
                                      while the plugin itself is located under:
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/compoSprayToolbar.rb:14
                                      OSX has a system Library folder and a User Library folder that looks very similar, and some users end up adding plugins to User Library. And I think Podium installs there.
                                      And then you can get issues with Sketchup.find_support_file
                                      The best way to determine the base path of your supporting folders are:
                                      File.dirname(__FILE__)
                                      In your case it'd be:
                                      @path_cs = File.dirname(__FILE__) + "/CompoSpray/"
                                      However, that won't work in .rbs files.
                                      In Vertex Tools I made the uncrypted loader, which was a regular .rb file, determine the paths and assign it to constants which the .rbs files could use.
                                      I've never had any path issues that way, and the plugins can be installed anywhere on the system. (if the user prefers to install in a custom location.)
                                      • U
                                        unclex
                                        if { mx_hidemanager.rb (C) 2010 by Henry Schorradt } this plugin was loaded,
                                        when set [Allow Collision] no, run CompoSpray
                                        SU8Pro crashed.....
                                          dcrites
                                          Does anyone have a solution for the problem which Pilou posted earlier? I have a 15" HP Laptop running windows 7, with Google Sketchup 8 -
                                          I'm a Landscape Architecture student, so spraying trees rather than placing them individually would be an absolute godsend. But if I can't get to the bottom of the screen, I can't do much. I've tried using the 'tab' key to get to the 'spray' icon, but it doesn't seem to work (though tabbing over to the 'close' icon does. Arg.
                                          768 pixels is the maximum height on my monitor.
                                          • Didier BurD
                                            Didier Bur
                                            I'll release an update soon with settings for low res screen that will set up scrollbars and modal/non modal dialogs. Easy and quick translation files will be supported as well.
                                            Regards
                                            DB
                                            • 13
                                            • 14
                                            • 3 / 14
