    Vray Frosted Glass
    renderpluginsextensions
    7 Posts 3 Posters 5.5k Views 3 Watching
      dmiller13
      Can someone let me know how to setup Vray in order for light to be affected by frosted glass? I have set up this render to demonstrate my issue:
      The block in front should still cast a shadow through the glass plate but it somehow doesn't.
      I ultimately want to use frosted glass as a window in an interior scene but so far any modification I make to the material still sees the rendered light with a sharp outline as though the glass were opaque.
      Thanks,
      Drew
        1. Please post your VfSU version when asking questions.
        2. Can you post that sample model? Not sure what is going on there.
          Have you applied the glass material on both sides of the face?
          Have you ensured that the front side of the face is pointing outwards?
          dmiller13
          Here it is:
          I placed another block in front of the window to make sure I set the frost correctly. But you can see that the light falls sharply on the ground. Is there a way to set this up to diffuse through the window?
          SketchUp V7.1
          Vray V1.48.66
            The latest public release is Vray V1.48.89 - I strongly recommend you upgrade as it fixes a number of issues. (The beta fixes even more - but you need to be part of the beta team for that.)
            What is the settings you have for your refraction layer? Do you have Affect Shadows enabled?
              dmiller13
              No problem, I'll get that update ASAP.
              That's it! I hate when it's something so simple! It has now changed to a soft light.
              Thanks a lot.
                πŸ‘ πŸ˜„
                  josephmanickaraj
                  Sir,i have the same problem,frosted glass doesn't affect the shadows
                  attached screen shots,
                  My VfSU version is 1.49.01,
                  i couldn't figure out my mistake,please help
                  Loving
                  Manickaraj
                  Material Setting
                  frame buffer
