    [Plugin] Component Edit Window v1.3 12072011
    46 Posts 18 Posters 58.2k Views 18 Watching
    • dereiD
      derei
      @tig said:
      dereeei
      Edit the .rb file at lines #55-56 using Notepad or similar plain text editor
      Thank you very much. All is fine.
      DESIGNER AND ARTIST DEREI.UK
      • TIGT
        We've decided to post an updated version of this useful tool.
        It corrects a rare glitch reported the the recent post.
        Get the updated version from here http://forums.sketchucation.com/viewtopic.php?p=296715#p296715
        As you probably know, sadly the script's author died a few weeks ago, he would have done it if he could 😞
        • TIGT
          Here's a version that attempts to fix a glitch on the MAC, deleting temp files
          Please remember to name components without characters that mess with system like NO /:<>?* or accented characters etc...
          As you probably know, sadly the script's author died a few weeks ago, he would have done fixed this if he could 😞
          • jeff hammondJ
            jeff hammond
            tested new version on mac. (v1.2)
            there's no ruby message this time (re: that other thread discussing this)
            i named a component 'test'
            context menu -> component edit window
            popup "insert instance: test" -> OK (in the previous version, after clicking OK is when the error message appeared in the ruby console)
            nada
            dotdotdot
            • TIGT
              Sorry Jeff... It's not my baby and I have a zillion other things to do... I think we stick here for now 😒
              • jeff hammondJ
                jeff hammond
                nah.. it's all good..
                i'll make a macro later today that does this so i can try out it's functionality in real world use.. i'll post my thoughts on it afterwards
                dotdotdot
                • TIGT
                  I've made several adjustments to the code, so it should now run on MAC OK.
                  Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=296715#p296715
                  Please remove all earlier versions from your Plugins folder...
                  • jeff hammondJ
                    jeff hammond
                    hey Tig,
                    it's getting close..
                    the new window open's with the component exploded and it's ready to edit..
                    the problem now is getting it back into the original window.. saving the EDIT and closing does nothing.. (and i tried all sorts of different ways of closing the window and saving..)
                    there is a file being created at:
                    /private/var/folders/yn/jr1p5r352bb_031xsl6c3r7c0000gn/T/testbox-EDIT_WINDOW.skp
                    so that part is working.. i did notice that upon saving i also had a file in the same location named testbox-EDIT_WINDOW~.skp
                    the tilde ~ represents a backup .skp on mac (we don't have .skb)...
                    so i turned off my backup preference meaning the original testbox-EDIT_WINDOW.skp would be overwritten with the new edits upon saving but still no luck..
                    not sure how you're going to figure this one out for mac -without having a mac to test on - since we have only the one instance of sketchup open at any given time.. πŸ˜‰
                    i did make a macro that does what this script is doing and it turned out pretty cool.. I'm not sure how much i'll use it but i can see the benefit..
                    i'm sure it's a bit more primitive than ruby.. mostly just uses keystrokes/menu items but it's fast and works well..
                    dotdotdot
                    • TIGT
                      It'd be easy to remove the ~.SKP [MAC-SKB] file, just as the SKB is removed on the PC...
                      BUT when you Save the EDIT_WIDOW version it should auto-close and the other original SKP window underneath should be still open and a dialog pop up asking you if you want to update the Component.
                      On OK it updates it and the temp SKP/SKB are removed from the temp folder...
                      If you just Close the EDIT_WINDOW version then you should just revert to the original SKP window underneath it, with not changes or prompts and the temp files removed.
                      What's happening on your MAC ?
                      Does the original window stay open ?
                      On a PC the second SKP opens an 'edit' window above the original...
                      • D
                        driven
                        What's happening on your MAC ? It's Group#[*]~.skp in -TMP- folder and on save then makes Group#[*].skp also in -TMP- folder.
                        Neither are 'purged' from the -TMP- folder on close or restart.
                        What's happening on your MAC ? No auto close, just saves. The original is underneath oblivious to changes. Not bought forward, no pop up.
                        What's happening on your MAC ? Same, but files remain.
                        Yes, window stays open.
                        Yes, above original.
                        also...
                        After reopening the original drawing, if you select the same group again, it opens the pre-existing drawing from -TMP-
                        john
                        • TIGT
                          Part of it is possibly the bugged onQuit AppObserver on MAC β˜€
                          The onSave AppObserver should close the window too at that point - I didn't think that was buggy on the MAC ?? πŸ˜•
                          What are the EDIT_WINDOW and its backup file after a save [in the temp folder] called on a MAC - should be like "Compo#1-EDIT-WINDOW.skp" ?
                          The temp file for the original SKP is not involved...
                          I'm at a loss - works fine on PC... any MAC gurus want to chip in ??
                          • D
                            driven
                            my #group[*]~.skp was me being lazy, sorry...
                            for both groups and components that are inside groups it creates files called Group#13-EDIT_WINDOW~.skp, the number being variable.
                            for a component in the wild I then get Component#1-EDIT_WINDOW.skp
                            and when I save that I get Component#1-EDIT_WINDOW~.skp
                            all are in the -TMP- directory/folder as well as any AutoSave_Group#12-EDIT_WINDOW.skp
                            I think leaving off the numbering would be better as then it would overwrite existing, so the most you would have is 4 files.
                            otherwise this gets rid of them from terminal
                            UpStairs-2:-Tmp- johns_iMac$ rm *.skp
                            john
                            • TIGT
                              All of these temp files are auto-erased in the PC version... something is adrift with the MAC though πŸ˜•
                              • jeff hammondJ
                                jeff hammond
                                they aren't erased until you reboot.
                                dotdotdot
                                • D
                                  driven
                                  I never turn my computer unless SU hangs...
                                  that's quite regular in fact...
                                  john
                                  • jeff hammondJ
                                    jeff hammond
                                    I hardly ever turn mine off either.
                                    you don't just force quit sketchup when it hangs?
                                    dotdotdot
                                    • D
                                      driven
                                      Usually, but I do have one or to openGL experiments that completely freeze the entire computer.
                                      I use to use my 'killall SketchUp button' but it wipes out the license, and it's a pain to re-add, because it's actually still there... [ etc, ect... easier to turn it off.
                                      • peter_shawP
                                        peter_shaw
                                        doesn't work with SU 2013. does not ask for updating when you save the component. the SU podium plugin "edit in place" just crahses my SU when i save. 😞
                                        • JQLJ
                                          JQL
                                          In 2013 the geometry will update if, after you edit component and save, you richtclick on the component and "reload" it on the original model window!
                                          Honolulu,
                                          I usually work with components as Xrefs. I use save as and reload a lot and also use Xref tools.
                                          Is there any possibility for this plugin to skip the temporary file and only edit the external file referenced by sketchup, (if it is referenced exists)? This way I wouldn't need to manually open a xrefed file to edit it and your plugin wouldn't change the association between the model component and it's file...
                                          Another thing it should do before editing that file is that it should overwrite it first before opening it, so one wouldn't accidentaly be editing an older version than the one that exists on the drawing.
                                          Thanks,
                                          JQL
                                          Would
                                          www.casca.pt
                                          Visit us on facebook!
                                          • TIGT
                                            Tragically this tool's author died some time ago...
                                            So none of his tools are going to get updated... unless someone else takes on the task... πŸ˜•
                                            • 2 / 3
