    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Most impressive SketchUp modelling
    266 Posts 93 Posters 346.9k Views 93 Watching
    • jgbJ Offline
      jgb
      I'm not into post-process rendering, but that was impressive. I watched about 50% (fast fwd through repetitive stuff) and that was an education in itself. I'm a big fan of layers in SU, but using layers like he did in post was an eye opener, and for what little of that I do in my photoeditor, I will be using layers to edit. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
      jgb
      • jgbJ Offline
        jgb
        OK, this isn't SU modeling. ๐ŸŽ‰
        I was on the net researching Planetary Gear Drives and computing their ratios, when I found this link.
        It gave me the calcs I needed, but then later I started to explore some of the links on the page, and a few hours later, I'm here.
        Go to this page, go 1/2 way down and click on "Planetary Gear Drive" or any of the links on page bottom, go watch some videos and be amazed. ๐Ÿ˜ฎ
        http://woodgears.ca/gear/planetary.html
        And my SU model in part....... (resulting from that research)
        Attached are 4 pics of the gearbox for an actuator I'm working on on my big airplane project.
        (Straight from SU, no post rendering)
        Sun & Ring Gears - Sun is stationary, the Ring is Input.
        Planet Gears & Spider.  The Spider is Output.
        Assembled gearbox.  Total ratio in this config is .6:1
        Backside view.  The Octagonal ring overlaps the Ring gears octagonal outer edge to drive a cascade of 2 or more gearboxes.
        jgb
        • jason_marantoJ Offline
          jason_maranto
          That stuff from Scifiwarships is really awesome -- highly render-able too, this a is try out of Maxwell and you can see his stuff really is ready to go.
          Model by Scifiwarships
          Thank-you for the heads up, I'll be keeping an eye on him.
          Best,
          Jason.
          • MarianM Offline
            Marian
            You're welcome, he's awesome ๐Ÿ˜„ and by the way nice render.
            • H Offline
              Hussel Hann
              Hi all...
              Just wondering...are there any amazing designs that created just by using pure google sketchup (without additional plugins).
              I am a newbie here, so my question might look stupid. ๐Ÿค“
              • jgbJ Offline
                jgb
                @hussel hann said:
                Hi all...
                There is no such thing as a stupid question, especially when from a novice.
                The object behind nearly all pluggins is either to correct a deficiency or to enhance a feature, or most usually, make a tedious task easier, faster or more accurately.
                The rendering you see in preceding posts are all after the fact of drawing the model. There is very little "rendering" capability in SU, so 3rd party apps or pluggins are needed to "put the lipstick and eye shadow" on. You still need the skills in SU to make a realistic model before you dress it up.
                So, yes, you can make a model in SU without any pluggins, but it will take a lot more effort.
                As an example, I design airplanes, and not just the exterior views, I put in components and assemblies, such as structure, mechanics, etc. It used to take me a week to make a fairing (the curved skin where 2 parts of the structure meet, such as wing to fuselage) in native SU.
                Then Curviloft came along and that reduced to about 2 days. I need to draw both the outer skin or moldline and the inner surface of composite panels that were usually 1/2 to 1 inch thick. I could not simply copy the outer skin 1/2 inch away, then join the edges, as the inner curve changes with the thickness.
                Then Joint-Push-Pull came along and the construction time for a fairing is now a few hours.
                jgb
                  jason_maranto
                  Every so often you see somebody talking about how they made such and such complex model and only used native SketchUp tools -- first of all that is meant to be bragging... and secondly I have to think they are:
                  a) Crazy
                  b) Stupid
                  c) Ignorant
                  d) Lying
                  or all of the above.
                  Unless you are the type who enjoys shoving splinters under your fingernails to prove how tough you are, you would be a fool not to avail yourself of the tons of free and incredible ruby scripts that are made for SketchUp... they will save you much time and frustration, and possibly open new avenues of creative expression.
                  Best,
                  Jason.
                    I can create a photoreal image with Paint!
                    • soloS Offline
                      solo
                      I can do photoreal with etch-a-sketch. ๐Ÿ˜„
                      http://www.solos-art.com
                      • MarianM Offline
                        Marian
                        I can do photoreal with my camera...wait..
                        • jgbJ Offline
                          jgb
                          Very well said Jason. ๐Ÿคฃ
                          jgb
                          • david_hD Offline
                            david_h
                            Me too!
                            Paint!
                            • pmolsonP Offline
                              pmolson
                              i am photo real
                              • boofredlayB Offline
                                boofredlay
                                I can create the most amazing and complex SketchUp model with native Autocad tools.
                                • hellnbakH Offline
                                  hellnbak
                                  I can create something completely unrealistic using all the plugins that I don't have a clue about (I can also do it without using any plugins)
                                  • H Offline
                                    Hussel Hann
                                    thanks guys..btw you're all very funny.. ๐Ÿ˜†
                                    actually i have downloaded so many plugins after a few days exploring sketchup.
                                    i think i need to do lot more exercise before playing with all the plugins. ๐Ÿ˜„
                                    its a loooooong way...
                                    • MarianM Offline
                                      Marian
                                      KARANAK strikes again
                                      http://fc02.deviantart.net/fs70/f/2012/076/4/e/maelstrom_by_karanak-d4t0rdy.jpg
                                      http://star-conflict.com/upload/image/materials/Making_of4/46.jpg
                                      http://karanak.deviantart.com/
                                      http://www.conceptart.org/forums/showthread.php?t=234083
                                      • soloS Offline
                                        solo
                                        Holy crap! what version of SU is he using, or what rig has he got? My SU 8 pro with tons of ram and i7 will never in a million years handle that complexed model.
                                          jason_maranto
                                          Bookmarked! ๐Ÿ‘ โ˜€
                                          • MarianM Offline
                                            Marian
                                            It must be something beyond us mere mortals. Besides, I doubt I would ever have the patience to model such a detailed ship.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 13
                                            • 14
                                            • 8 / 14
