    Most impressive SketchUp modelling
    266 Posts 93 Posters 416.8k Views 93 Watching
    • hellnbakH
      hellnbak
      Just had to submit these, a Honda CT70 motorcycle created by unigami. Incredible detail!
      • Z
        zzchatom
        http://img31.imageshack.us/img31/7759/frontqam.jpg
        By zzchatom at 2012-01-26
        http://img521.imageshack.us/img521/4283/backrbe.jpg
        Uploaded with ImageShack.us
        Architecture bridge house Model
        • L
          liam887
          That is great!
          VISIT MY ONLINE GALLERY
          • MarianM
            Marian
            Sorry for the big pictures I couldn't resize them with the HTML code.
            Here are some awesome spaceships done by Scifiwarships. http://scifiwarships.blogspot.com/view/flipcard
            http://scifiwarships.deviantart.com/gallery/ http://sketchup.google.com/3dwarehouse/search?q=scifiwarships&styp=m&scoring=t&btnG=Search
            http://th00.deviantart.net/fs71/PRE/f/2012/020/a/3/phallanx_tactical_battle_drone_by_scifiwarships-d4n16mq.jpg
            Rendered with Kerky
            http://fc04.deviantart.net/fs70/f/2012/036/b/b/tac_bat_painted_by_mikemars_by_scifiwarships-d4orxmo.jpg
            Painted in PS by Michael Marsicano http://mikemars.deviantart.com/gallery/
            http://th04.deviantart.net/fs70/PRE/f/2012/031/a/0/meridian_battlecruiser_colors_by_scifiwarships-d4o9aub.jpg
            • MarianM
              Marian
              Also here are the videos showing how that ship was painted ovr in PS.
              http://vimeo.com/35482176
              • hellnbakH
                hellnbak
                Wow, I'll bet this guy sleeps in a spacesuit with a phaser under his pillow ๐Ÿ˜† I'm not really into spacecraft that much but these are some of the best I've seen. He doesn't go overboard with the details like some I've seen, they are clean and very well thought out.
                The video tutorial on post processing is excellent, I've only watched about 6 minutes of it and already I've learned a lot.
                Thanks for posting this Marian ๐Ÿ‘
                • MarianM
                  Marian
                  Yeah he is pretty amazing.
                  You're welcome ๐Ÿ˜„
                  • jgbJ
                    jgb
                    I'm not into post-process rendering, but that was impressive. I watched about 50% (fast fwd through repetitive stuff) and that was an education in itself. I'm a big fan of layers in SU, but using layers like he did in post was an eye opener, and for what little of that I do in my photoeditor, I will be using layers to edit. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    jgb
                    • jgbJ
                      jgb
                      OK, this isn't SU modeling. ๐ŸŽ‰
                      I was on the net researching Planetary Gear Drives and computing their ratios, when I found this link.
                      It gave me the calcs I needed, but then later I started to explore some of the links on the page, and a few hours later, I'm here.
                      Go to this page, go 1/2 way down and click on "Planetary Gear Drive" or any of the links on page bottom, go watch some videos and be amazed. ๐Ÿ˜ฎ
                      http://woodgears.ca/gear/planetary.html
                      And my SU model in part....... (resulting from that research)
                      Attached are 4 pics of the gearbox for an actuator I'm working on on my big airplane project.
                      (Straight from SU, no post rendering)
                      Sun & Ring Gears - Sun is stationary, the Ring is Input.
                      Planet Gears & Spider.  The Spider is Output.
                      Assembled gearbox.  Total ratio in this config is .6:1
                      Backside view.  The Octagonal ring overlaps the Ring gears octagonal outer edge to drive a cascade of 2 or more gearboxes.
                      jgb
                      • jason_marantoJ
                        jason_maranto
                        That stuff from Scifiwarships is really awesome -- highly render-able too, this a is try out of Maxwell and you can see his stuff really is ready to go.
                        Model by Scifiwarships
                        Thank-you for the heads up, I'll be keeping an eye on him.
                        Best,
                        Jason.
                        • MarianM
                          Marian
                          You're welcome, he's awesome ๐Ÿ˜„ and by the way nice render.
                          • H
                            Hussel Hann
                            Hi all...
                            Just wondering...are there any amazing designs that created just by using pure google sketchup (without additional plugins).
                            I am a newbie here, so my question might look stupid. ๐Ÿค“
                            • jgbJ
                              jgb
                              @hussel hann said:
                              Hi all...
                              There is no such thing as a stupid question, especially when from a novice.
                              The object behind nearly all pluggins is either to correct a deficiency or to enhance a feature, or most usually, make a tedious task easier, faster or more accurately.
                              The rendering you see in preceding posts are all after the fact of drawing the model. There is very little "rendering" capability in SU, so 3rd party apps or pluggins are needed to "put the lipstick and eye shadow" on. You still need the skills in SU to make a realistic model before you dress it up.
                              So, yes, you can make a model in SU without any pluggins, but it will take a lot more effort.
                              As an example, I design airplanes, and not just the exterior views, I put in components and assemblies, such as structure, mechanics, etc. It used to take me a week to make a fairing (the curved skin where 2 parts of the structure meet, such as wing to fuselage) in native SU.
                              Then Curviloft came along and that reduced to about 2 days. I need to draw both the outer skin or moldline and the inner surface of composite panels that were usually 1/2 to 1 inch thick. I could not simply copy the outer skin 1/2 inch away, then join the edges, as the inner curve changes with the thickness.
                              Then Joint-Push-Pull came along and the construction time for a fairing is now a few hours.
                              jgb
                              • jason_marantoJ
                                jason_maranto
                                Every so often you see somebody talking about how they made such and such complex model and only used native SketchUp tools -- first of all that is meant to be bragging... and secondly I have to think they are:
                                a) Crazy
                                b) Stupid
                                c) Ignorant
                                d) Lying
                                or all of the above.
                                Unless you are the type who enjoys shoving splinters under your fingernails to prove how tough you are, you would be a fool not to avail yourself of the tons of free and incredible ruby scripts that are made for SketchUp... they will save you much time and frustration, and possibly open new avenues of creative expression.
                                Best,
                                Jason.
                                  I can create a photoreal image with Paint!
                                  • soloS
                                    I can do photoreal with etch-a-sketch. ๐Ÿ˜„
                                    • MarianM
                                      Marian
                                      I can do photoreal with my camera...wait..
                                      • jgbJ
                                        jgb
                                        Very well said Jason. ๐Ÿคฃ
                                        jgb
                                        • david_hD
                                          david_h
                                          Me too!
                                          Paint!
                                          • pmolsonP
                                            pmolson
                                            i am photo real
                                            • 13
                                            • 14
                                            • 8 / 14
