    [Plugin] OBJexporter v3.0 20130131
    304 Posts 96 Posters 586.2k Views 96 Watching
      @nightwasp said:
      Thanks. The directions were simply to put it into the plugins folder. I did that and even tried changing the extension from .rb to .plugin to match the other files. I appreciate the link but the permissions were already fine, but I redid them all just to see if that made a difference. Sadly, no. But thanks for the input!
      A plain .rb file can be manually put into the Plugins folder, and provided you have proper permissions when SketchUp restarts it will load. In the case of this particular plugin it appears in the File menu...
      Most plugins are now available through the SketchUcation PluginStore.
      These can be downloaded as RBZ archives - e.g. http://sketchucation.com/pluginstore?pln=OBJexporter and these can be auto-installed using the Preferences > Extensions > Install... button which puts all of the archives contents in the right places for you - provided there are sufficient permissions to do so... and you have SketchUp v8M2 or newer...
      If you get and install the RBZ for the SketchUcation Plugin Store Toolset... that will allow you to install any Plugin from a dialog within SketchUp itself without even having to worry about downloading an RBZ archive... It also has an Installed to use with loose RBZ/ZIP archives and Managers for Plugins and Extensions etc...
      These alternatives remove the headache of manual installation etc, and some have been available for several years... πŸ˜•
      Never change a file's extension - if it's ".rb" SketchUp will auto-load it as it starts... Anything else is ignored - where did you get the ideas that SketchUp plugins end in ".plugin" - no other files with that file-type should be in the SketchUp plugins folder ? Only .rb and .rbs plugins are auto-loaded by SketchUp from its Plugins folder - ones disabled by the SCF Plugins Manager end with an additional "!", ones uninstalled by the SCF Uninstaller end with an additional "x"... πŸ˜’
      Note how RBZ files are special kinds of ZIP files that SketchUp can install the contents of...
      I did a grep on my PC and Fredo does have some files inside his tools' subfolders that end in ".plugin"... BUT these should never be loose in the Plugins folder - so if there are this suggests a mis-installation of at least that tool too... For example it is:
      Program Files\SketchUp\SketchUp 2013\Plugins\**Fredo6_Curviloft\**Curviloft.plugin
      NOT
      Program Files\SketchUp\SketchUp 2013\Plugins\Curviloft.plugin
      The actual file that goes with that tool is:
      Program Files\SketchUp\SketchUp 2013\Plugins\**Fredo6_Curviloft.rb**
      which in turn starts a chain reaction which loads other files from its sub-folder like .rb, .lang etc... unusually Fredo uses these special ".plugin" files for each of his tools to provide a text list of 'Plugin Registration' data, which is then read in by his 'Lib6core.rb' code, which in turn actually loads his tools as Extensions [that's why you need his latest Lib installing to load and run his tools]... So a ".plugin" file does nothing 'on its own' and it should always be left where it is shipped... inside its tool's subfolder... like all other 'nested files' which may come with complex plugins...
      To find you Plugins folder type this into the Ruby Console:
      Sketchup.find_support_file('Plugins')
      It will return a path to the folder... For v2013 it is typically:
      C:\Program Files\SketchUp\SketchUp 2013\Plugins
      Idea πŸ’­
      If you manually put plugin files in the old v8 Plugins folder they will NOT get found by v2013 ! 😲
      Post a list of the files in the v2013 Plugins folder - I suspect you have messed up something big time...
      Also double-check your permission to the v2013 Plugins folder etc...
      You seem to be having more problems than you ought to... πŸ˜’
      • N Offline
        nightwasp
        Auto installing the .rbz file WORKED! I had manually put the .rb file in the only plugins folder I saw in the programs three main folders without success. I want to thank you all for not only helping, but helping in such a timely manner! Best. Keith
        • P Offline
          pete69
          For SketchUp 2014 Make, put the .rb file into the Tools folder.
            No.
            You only need to drop RB files into the Plugins folder with pre-v8.
            All newer versions of SketchUp [>=v8M2/v2013/v2014] can install the contents of RBZ archives into the correct Plugins folder automatically...
            The SketchUcation PluginStore dialog will AutoInstall selected Plugins for you, side stepping you even having to download the RBZ ! It even reports available Updates for you, manages laoded/unloaded plugins and extensions etc etc...
            http://sketchucation.com/pluginstore?pln=SketchUcationTools
            The SketchUcation Toolset's submenu includes 'Archive Installer' also installs RBZ [and ZIP] archives into the Plugins folder and [unlike the native installer] it offers you the choice of installing into a custom-plugins folder - if you have one predefined in the $LOAD_PATH, perhaps using Fredo's AdditionalPluginsFolder tool...
            This 'add-on' to the SketchUcation Toolset also simplifies accessing the default Plugins folder...
            http://sketchucation.com/pluginstore?pln=SCF-openPluginsFolder
            Virtually all of the Plugins on SCF are available from the PluginStore in RBZ format...
            • H Offline
              HazelG
              Hi I have downloaded the exporter but how do I install it into sketchup?
                Are you really still on SketchUp v7 ? πŸ˜•
                SketchUp v8 or v2013 or v2014 offer a simple tool - Preferences > Extensions > Install... button - which extracts and auto-installs the contents of an RBZ archive into the correct Plugins folder for you - 'error free'...
                Why not update to something newer - there are many improvements...
                Assuming you stick with v7 πŸ˜’
                Even if you get some plugins installed they might not work with such an early version - but luckily for you this OBJexporter should just about work in v7 !
                If you want to install the contents of any RBZ into v7 do these one off fixes...
                Find the v7 Plugins folder...
                If you are unsure where it is in the Ruby Console type:
                and the full path is returned...
                Check that the v7 Plugins folder has FULL security permissions set for everyone in the list...
                With Admin powers [make yourself an Admin in the Users Control-Panel...]
                Select the v7 Plugins folder's icon.
                Right-click > Context-menu > Properties > Security > Edit... >>> FULL for each and every...
                Now select the v7 SketchUp.exe icon which is in the same folder as the Plugins folder.
                Right-click > Context-menu > Properties > Compatibility > check the box near the bottom Privilege Level > Run this program as an administrator.
                To install the RBZ contents...
                Find the RBZ archive.
                If it's in the Plugins folder move it somewhere sensible - like your Desktop or Downloads folder.
                If necessary change your Windows Explorer's Folder Options to show all file-type suffixes...
                Now select the RBZ.
                Right-click > Context-menu > Rename
                Add .zip onto the end of its name.
                When warned accept the change anyway.
                Now you have a ZIP file [an RBZ is simply a ZIP file with another suffix!]
                Use your Decompression Program [you surely have one] to extract the contents of the ZIP into a temporary folder named after the archive.
                In the case of this plugin there will be an RB file in this temporary folder.
                Move that RB file into the v7 Plugins folder.
                Delete the now empty temporary folder as it is no longer needed.
                Restart SketchUp v7 to load the plugin.
                Note that for this particular plugin the contents are as simple as it gets [just the one RB file] but many more other plugins come with additional files in the RBZ inside a subfolder [often named after the RB itself] - perhaps with nested subfolders of files.
                In that case the contents of the temporary folder must be moved into the Plugins folder fully intact - with all such support files remaining in their subfolder[s] unchanged.
                The main issue with manual installations in previous versions of SketchUp [like v7] was that inexperienced users often mess this step up and end up with files in the wrong place, preventing the plugin loading properly, or sometimes even breaking SketchUp itself as misplaced RB files load at startup unexpectedly... that is exactly why the auto-install using an RBZ archive was devised !
                Good luck... πŸ˜„
                  jorgemanes
                  Hi, I'm trying to install OBJexporter_v3.0.rbz in the plugins folder of sketch up, mac. After pasting it there, I cannot see the option when I go to File>
                  All the files in the plugin are .plugin, probably I'm doing something wrong, any help? thank you
                    You need to read up on how to install plugins from RBZs...
                    You do NOT put the RBZ file into the Plugins folder.
                    Your comment that all files in the plugins folder are .plugins is another mystery !
                    The proper SketchUp Plugins folder contains none of these file-types - most files in it will be .rb !
                    I suspect a double-whammy! The wrong folder AND an incorrect idea on what to do with an RBZ file...
                    So, let's fix this mess... πŸ˜•
                    Move the RBZ file back to somewhere sensible - your Desktop seems like a good idea...
                    Open SketchUp 2014.
                    Open its Preferences.
                    Open Extensions.
                    Click the 'Install...' button...
                    Navigate to the appropriate folder [e.g. Desktop], and choose the RBZ.
                    Answer OK to prompts...
                    The Plugins file[s] should now be extracted from the RBZ and installed in the correct Plugins folder, and loaded so as to be available to use.
                    Note that Plugin tools can appear in any locations in the SketchUp top-bar menus, but in this case it IS found under the 'File' menu [but often they can be located in 'Plugins' menu, read the guidance for each tool's installation/usage]...
                    • E Offline
                      E0068675
                      I cannot thank you enough for making this exporter!!
                      You have literally saved me hundreds of $$$$
                        == Donation 😲
                        • K Offline
                          Kaylle
                          I get this error:
                          http://i.imgur.com/AvOgQob.png
                          I did this:
                          Windows > Preferences > Extensions > Install Extension...
                          I selected OBJexporter_v3.0.rbz then restarted Sketchup 8.0.11752 (free version) and I got that error.
                            There is an important system file, named sketchup.rb which is shipped with SketchUp.
                            It is in the ../Tools/ subfolder inside the main 'SketchUp' folder.
                            If you have somehow deleted it nothing will load if it requires it.
                            In v8 you should have at least these files in ../Tools/
                            sketchup.rb extensions.rb langhandler.rb
                            There might be other files too...
                            These files should NEVER be found in the ../Plugins/ folder !
                            The set up with newer SketchUp versions is slightly different, but the same principles apply...
                            • K Offline
                              Kaylle
                              Thanks, a few folders got jumbled and files were accidentally duplicated (or got corrupted) that's why it didn't work.
                                StarLand
                                I have download so I'll export my models as test.
                                I hope the results are good. πŸ˜„
                                edit:
                                It's works fine.
                                  meff1091
                                  i am using your objexporter to export my models to pepakura to make paper model of them. i am having this issue:
                                  if my model has different coloured faces like this:
                                  , exported obj file look like this in pepakura:
                                  and i am sure all edges connected. if i export kmz4 with skp6, i have no problems with pepakura. but you know sketchup 2016 is newer and faster than old one. i want to use the 2016 but this objexporting issue botters me. any ideas on this?
                                    OBJ exporters typically triangulate the 'mesh'.
                                    It's hard to see exactly what the problem is in 'Pepakura' ??
                                      myreiko
                                      ty
                                        Saturo
                                        I have the problem that the OBJexporter sometime produces shading error like this:
                                        http://picup.oliverlamm.de/files/IMG_bf869069836ff46db79c3034ccec65c5_36mzFlCf85_Ok_small.jpg
                                        Any suggestions how i can prevent this?
                                          A little more info about what we are looking at, perhaps a SKP exhibiting the problem, or an OBJ/MTL/Textures ZIP ?
                                          Otherwise it'll involve wild guesses...
                                            Saturo
                                            The issue can be easily reproduced.
                                            Build a face. Place two other faces on it an put another material onto these two faces.
                                            http://picup.oliverlamm.de/files/IMG_2b4a64df798c484b7f040deabc7e0c36_36mzFlCf85_Ok_small.jpg
                                            Save and export as .obj-file.
                                            Import in Blender.
                                            After remove doubles and limited dissolve you can see normals not standing in 90Β° on the face, which are causing these shading errors, i guess.
                                            http://picup.oliverlamm.de/files/IMG_9415199a237946b96b06371ef659aea7_36mzFlCf85_Ok_small.jpg
                                            ](http://picup.oliverlamm.de/files/IMG_9415199a237946b96b06371ef659aea7_36mzFlCf85_Ok.jpg)
                                            If needed, i can upload the used files.
                                            best regards
                                            Christian
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
