    Loft curved face with Curviloft
    16 Posts 8 Posters 3.1k Views 8 Watching
    • J
      jhearcht
      SketchUp8.0 on Windows XP using Curviloft script
      I'm trying to add a compound curve face to edges in the attached file. Three edges are long curves and three are short straight lines. I edit the group and select all edges, then click the Curviloft icon for spline curves. After highlighting all edges and clicking the check mark, SU says "wait" and the dialog at bottom says "all connected". But nothing happens. However, if I draw a new straight line between two corners, a preview surface is drawn.
      I'd appreciate any suggestions to get the tool to add a face to the whole perimeter. The outline to be filled is on the Loft layer of the attached SU file.
      PS---Does anyone know where I can get some written instructions or a tutorial for Curviloft? I used it once before with no problem, but I still don't know all the requirements and limitations. Ruby Library didn't include or indicate anything except the script. The tutorial on this forum is way above my pay grade.
      Surface to be lofted
      • J
        jhearcht
        After a lot of fiddling and finagling, I finally got CurviLoft Skinning tool to add a compound curved face to the Loft Outline shown below. I still don't what I did differently, but I'll call it progress.
        Now the problem is that CurviLoft bunched up the surface and made an unwanted crease as shown in the Loft Hidden Lines below. The script reported that the selected edges were All Continuous. So I don't know where the crease came from.
        In the Remove Crease image, the original object has been mirrored, and should meet at a knife-edge. Instead there is a warped area that I can't account for. Any suggestions for avoiding or removing the crease will be appreciated.
        http://home.mindspring.com/~gnomon/Loft outline.JPG
        http://home.mindspring.com/~gnomon/Loft hidden lines.JPG
        http://home.mindspring.com/~gnomon/Remove crease.JPG
        • honoluludesktopH
          honoluludesktop
          While I don't use the plugin myself, I can see why the crease was generated. Btw, are you certain that the 2 lines on the left are coplaner, and meet at a knife edge with its companion surface? The bottom render seems to indicate that they do not meet as a knife edge.
          Perhaps for your purposes, the mesh should stretch out from the long line at the bottom, to the short line at the top. If possible, you might try to generate the mesh in different directions.
          • J
            jhearcht
            HD, as you can see in the first image above the skin was applied to a single non-coplanar outline. So all edges should be knife edges. I tried several of the lofting scripts, but only CurviLoft came close to a satisfactory rendering of the compound curved surface. All of the loft or skin plug-ins seem to be unfinished beta versions. So maybe that explains some of the glitches.
            After many wasted man-hours, I was about to give-up, when I decided to try the built-in Sandbox tools for the first time. Voila! It produced a reasonable surface the first time. It still has a few wrinkles, but at this point I can't be too fussy.
            I didn't know the Sandbox could be used for curved skins. I guess you live, and you learn . . . after much frustration. Anyway, here's an unfinished beta version of the model.
            http://home.mindspring.com/~gnomon/Gnomon tower preliminary.JPG
            • mitcorbM
              mitcorb
              There is a chance that Fredo6, the author of Curviloft will see this thread and respond. I know that Charly2008(I think that's right) has experience with the script. I have not had enough practice with it yet.
              My point is that you could post in the Curviloft thread for maybe quicker response, and either or both of these kind gentlemen will respond.
              • jeff hammondJ
                jeff hammond
                the problem is that this shape that you're trying to fill has more than 4 sides.. 5+ sides just isn't going to work out (and your shape actually has 7 sides once you examine it a bit further..
                probably the best tool for this job (well, the best tool as you have your curves set up right now) is soap skin bubble:
                http://www.tensile-structures.de/sb_software.html
                [and notice that the soap skin upon creation is also 4 sided.. it's just a bigger overall 4sided surface that has been trimmed to fit your shape].
                it works sort of like a patch tool in other modeling apps though a lot more restrictive..
                soapskinned.skp
                dotdotdot
                • charly2008C
                  charly2008
                  I have no problem. It works with Skinning of shapes without a crease.
                  Charly
                  Gnomon Tower_Loft face_12-15-10.skp
                  • jeff hammondJ
                    jeff hammond
                    @charly2008 said:
                    Charly
                    those are the curves from the file i uploaded.
                    try it with the .skp in the original post.
                    (but it's weird that you changed the name of my file to match that of the original post??)
                    [and also notice that it's still wrong.. there is a hump near the top seam.. not super noticeable in this exact file but if you exaggerate the shape's radii, you'll see the hump easier]
                    regardless, using curviloft on these curves is a bad idea.. notice the resulting surface has actually been divided into 4 separate surfaces which is where the kinks and folds come from (especially because you don't have much control over where those surface divisions will occur.. it's better to divide it yourself into 4 sided surfaces prior to surfacing)
                    look at this file for a more simplistic look at the problem..
                    5sides_vs_4sides.skp
                    dotdotdot
                    • charly2008C
                      charly2008
                      Sorry Jeff, that was not intended.
                      Charly
                        Or better Ferrari architecture plug ! 😉
                        • J
                          jhearcht
                          [/attachment]
                          The Tensile-Structure plug-in is one of the scripts I tried. I haven't found any detailed operating instructions for any of them. So my understanding of the theory and limitations is limited. The only video for CurviLoft demonstrated the Loft By Spline method. The Skinning method is the only approach that worked at all.
                          One thing that may cause the scripts to fail is the Jekyll/Hyde personality of the curved lines. They were drawn as ellipses, and then cut to fit the model. But when I edit the group and select the outline, Entity Info sometimes reports 48 edges, and other times reports one curve. Sometimes CurviLoft would select the whole outline with one click, and other times I had to select each major segment individually. What's up with that?
                          • jeff hammondJ
                            jeff hammond
                            well, the reason you're having problems with the selection is that there's a small break in the loop as shown in this picture...
                            re: user manuals for plugins..
                            i dunno, these guys write rubies .. not instruction manuals 😄
                            they get their thrill or fix or whatever you want to call it from coding but writing a manual is a lot of work for which i don't imagine they have much desire/motivation to produce.. if they were $50+ plugins which would maybe allow for a team to write the manual then sure, i guess it might make more sense..
                            [but then again, the most detailed instruction manual in the world wouldn't have done much good in this case]
                            dotdotdot
                            • jeff hammondJ
                              jeff hammond
                              the following is only sort of related to the original post but since i started talking about the 4 sided surfaces...
                              here's this thing that i've been wanting to build:
                              the curves defining the back look like this: (which sort of reminds me of the shape in the original post)
                              since it's more than 4 curves, a curve network wouldn't work so i either have to divide it into 4 sided parts or use a patch.. soapSkin&bubble seems to be the closest thing sketchup has to a patch. (but i haven't tried the ferrari plug that pilou posted)
                              this is the surface patch:
                              the thing to understand is that patch is still a 4 sided surface.. it's just that it's been trimmed by the six curves outlining the shape.. this is how the patch + it's trimmed portions look:
                              curviloft (and TIG's extrude edges) is suited to draw the untrimmed surface in the above pictures (the one defined by 4 curves)..it's not suited to simply fill in the 6 edges and if you try to do it anyway, it's going to chop the 6 edged surface into 4 edge surfaces that it can deal with.. (fwiw, if you try to use tools similar to curviloft in other software, it won't even permit the command to run as you're giving it bad input)
                              i brought the edges into sketchup.. this is what happens when you run curviloft on the 6 edges.. notice the resulting surface has been divided into three 4 sided surface (and there are 2 kinks where these surfaces meet making the drawing unusable)
                              this is cuviloft on the outer edges which is great input for curviloft and results in a clean mesh..
                              however, the surface isn't passing through the 6 edges.. this angle will show the error better..
                              in this instance (as well as dealing with the original post), soap skin & bubble handles the surface best.. [though i hesitate posting this because soapskin is a horrible go to for this type of stuff.. in this exact case, it's made out to be decent but there are other examples i could post of why using a tension based surfacer is a bad idea)
                              ..looking from the other side with x-ray on, you'll see that soapskin isn't quite right..
                              ..and, if i loosen the tension on the skin in order to get closer to that portion of the rhino surface, the error will multiply on the bottom part (the visible orange shown in the previous picture). i would really need to be able to loosen tension on some parts of the soap skin and tighten the tension on others in order to actually edit the surface to it's proper shape.. impossible to do with soapskin & bubble.
                              anyway, i think it'd be very nice to have a true patch tool in sketchup but to have one that functions similar to rhino's might be asking way too much of sketchup and/or the coders..
                              thomthom is working on a bezier patch but i'm not quite sure if it's going to function as shown in pics 1-3. (encompassing 4 sided surface which is then trimmed to the desired edges).
                              i guess i'm rambling on about nothing here but i felt like talking about it anyway 😄
                              dotdotdot
                              • J
                                jhearcht
                                Jeff, thanks for the semi-tutorial. I didn't know the Loft and Skin scripts were limited to four sided figures. That little piece of information may make the process much easier next time. Apparently, the Sandbox tool automatically divided the surface into four-sided sections. Which may be why it worked better than the other scripts.
                                I also wasn't aware that one corner was not connected. Because of the Loft selection glitch noted above, I used the "Weld" script repeatedly to combine all the selected edges into one entity. Apparently it didn't work as I imagined it would, to join all corners.
                                Anyway, now that I have---more or less successfully---used the Sandbox tool to create a skin, I still have some Artifact Edges to deal with. At certain angles the skin wrinkles display an edge as shown in the first image below. In the second image, the wrinkles seem to be on a single Face, so why does one have an Edge? (the grid on the face is an artifact of the screenshot and image compression)
                                My question now is, how can I get rid of (or hide) the Artifact Edge? I can see it, but I can't select it.
                                http://home.mindspring.com/~gnomon/Artifact Edge.JPG
                                http://home.mindspring.com/~gnomon/Artifact Wrinkles.JPG
                                • thomthomT
                                  Ugh... manuals... 😕 thinks back in dread of Vertex Tools' manual They are incredible tedious and boring things to do. 🤢 Dreading the work ahead for Bezier Surface. But they are valuable resources for users and needs to be there for commercial products.
                                  Quad and Tri patches is what computers like best and is the most predictable method for modelling. Bezier Surface will only work with Quad and Tri patches, but you assemble sets of patches into one surface. Just like 3dsMax's Patch modelling (and similar apps). So one always has to workout how you need to divide the surface into appropriate patches.
                                  [flash=640,385:t58edwaa]http://www.youtube.com/v/cIsd3xZJfZw?fs=1&hl=en_US[/flash:t58edwaa]
                                  [flash=640,505:t58edwaa]http://www.youtube.com/v/n31wkLX0oGw?fs=1&hl=en_US[/flash:t58edwaa]
                                  • T
                                    theabenindra
                                    Hello there ^^
                                    Newbie here and rescue needed 😢 😢 😢
                                    Does anyone ever create snail shell in sketchup as attached ?
                                    I need to adjust the size of the head (for the speaker) of shell and keep the snail shell body in that size..
                                    but i dunno how to do it (especially when i import the file from STL it become small pieces)..
                                    or i need create the new one.. ? 😢 😢 (hope not) 😢 😢
                                    If somebody here ever adjust it, kindly share how to do it.. 😞
                                    Many thanks,
                                    T
                                    Snail shell.skp
