    [Plugin] ImageAnimator 20130827
    18 Posts 10 Posters 15.6k Views 10 Watching
    • TIGT
      See here for download http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
      TIG (c) 2010 - 2013
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      [NB:definition and transformation methods are Copyright 2008, AlexM]
      ImageAnimator.rb
      Needs 'image_class.rb' [comes in the same folder]
      Adds new Tool 'ImageAnimator':
      Under Menu > View > ImageAnimator... [submenu]
      OR
      View Toolbars > ImageAnimator
      The Tools include the following:
      "Set Folder for Selected Image"
      This sets the 'folder' of sequential 'image-files' that will be used by the
      Image when its animation is run. The 'folder' chosen should contain images
      with sequential name/numbering as they will load in that order - e.g. as
      they are exported from a GIF or movie file - image001.png, image002.png etc
      They should also all be the same size and filetype[recommended]. PNG files
      can offer transparency so are preferred for 'cutouts' of people etc. Any
      set 'folder' are remembered across sessions with the SKP. If an Image has
      a 'folder' set that no longer exists then it is auto-reset to 'nil' and it
      will need redefining.
      "Set Folder from Selected Image to 'Nil'"
      This sets the selected Image(s) 'folder' to 'nil' thereby effectively
      removing its animation abilities. Should an Image has a 'folder' set that
      no longer exists then it is auto-reset to 'nil' and it will need redefining.
      "Set Timer for Selected Images"
      This sets the timer [in seconds] for the selected Image(s). It defaults to
      0.0 - this value means that the Image only animates as the active Scene tab
      changes. Any value > 0.0 sets the frame-rate in seconds - 0.1 to 0.2 are
      often suitable values - when the Images are animated their animation
      effects continue as you work/pan/zoom or make screen-captures etc.
      The shortest workable 'timer' is 0.01 seconds. Having several animations
      running simultaneously will slow down all animations frame-changes so if
      this situation is expected then reduce the frame rate of all animated
      Images appropriately.
      "Set FaceMe for Selected Images"
      This sets the selected Image(s) 'faceme' behavior. The choices are:
      'None' - the Image does not face the camera [default]
      'Bottom-Left' - the Image is placed into a special Group - 'FaceMeImage' -
      which faces the camera, pivoting around the Z_AXIS anchored at its
      bottom-left corner.
      'Bottom-Center' - the Image is placed into a special Group - 'FaceMeImage' -
      bottom-center point.
      'Bottom-Right' - the Image is placed into a special Group - 'FaceMeImage' -
      bottom-right corner.
      A 'FaceMeImage' Group is treated as if it were an Image by the
      ImageAnimator tools. If later on you reset its 'faceme' behavior to 'None'
      then the Group is exploded and the Image reverts to a plain Image.
      "Animate Selected Images"
      This starts the animation effects on the selected Image(s), using the
      'folder' and 'timer' that each one has set as attributes. Depending on its
      'timer' each Image will animate as the Scene tab changes or continuously as
      you work doing other things. The first frame in each Image's animation is
      the first image-file in its 'folder'.
      "Stop Selected Images Animation"
      This stops the animation effects on the currently selected Image(s).
      Each 'stopped' Image uses its currently loaded image-file.
      "Animate All Images"
      This starts the animation effects on ALL suitable Image(s) - i.e those with
      a 'folder' set; using the 'timer' that each one has set as an attribute.
      Depending on its 'timer' each Image will animate as the Scene tab changes
      or continuously as you work doing other things. The first frame in each
      Image's animation is the first image-file in its 'folder'.
      "Stop All Image Animation"
      This stops the animation effects on ALL Image(s).
      **Menu only items:--------------
      "Make_Unique"
      This processes the Selected Image(s) with 'make_unique', i.e. if there is
      more that one Instance of an Image in the Model then the Selected Image is
      given another Definition 0 it is a lone Instance so only it 'animates'.
      "Clone"
      If you manually 'Copy' an Image it becomes another Instance of the same
      Image Definition and the Instances will 'animate' together. You could use
      'Make_Unique' on the Copy to prevent this, alternatively use this 'Clone'
      function - it makes an exact 'copy' of the Selected Image over the original.
      However, it is a 'clone' and is 'unique' having a separate Definition, so it
      will 'animate' as a lone Image.**
      Donations:
      By Paypal.com to info @ revitrev.org PayPalButton
      Version:
      1.0 20101210 First issue.
      1.1 20101212 New Menu items added - Make_Unique and Clone
      1.2 20101213 Typo corrected in new menu / toolbar code.
      1.3 20101216 Typo in menu corrected - again!
      1.4 20110105 Clone menu typo fixed.
      1.5 20130827 Temp folder issues resolved.
      Also see these example movies [flash=630,450:2kzjnyky]http://www.youtube.com/v/5e_BrXfXXCI[/flash:2kzjnyky]
      [flash=630,450:2kzjnyky]http://www.youtube.com/v/3KeAjT_W28I[/flash:2kzjnyky]
      • TIGT
        Update added with 2 new menu items Make_Unique and Clone - see here http://forums.sketchucation.com/viewtopic.php?p=293698#p293698
        PS: The SUp 'timers' pre-v8 can be buggy and only work in whole seconds. Try various timer values to see what you get but you might find 'fine-tuning' of the frame timers only works well in v8............. ๐Ÿ˜’
        • jason_marantoJ
          jason_maranto
          Very cool stuff, and I like the videos too.
          Best,
          Jason.
          • R
            rv1974
            At last TIG started to add video explanations ๐Ÿ˜ฒ ๐Ÿ˜„
            • kenK
              ken
              Since what I design is used in the ocean, I did this photo animation. I made the sea from the program MiniOcean.
              Just wanted to see what the two would do together.
              Ken
              SeaTest.wmv
              • soloS
                solo
                Ken, thats pretty cool, can you show a SU screen shot so I can better understand what I just saw?
                Oh, you are the winner, I have never seen so many toolbars ๐Ÿ˜ฒ , I'm not even sure I know half of them.
                http://www.solos-art.com
                • FrederikF
                  Frederik
                  +1 ๐Ÿ˜ฎ
                  Cheers
                  Kim Frederik
                  • kenK
                    ken
                    [quote="solo"]Ken, thats pretty cool, can you show a SU screen shot so I can better understand what I just saw?
                    Oh, you are the winner, I have never seen so many toolbars ๐Ÿ˜ฒ , I'm not even sure I know half of them.[/quot
                    The video is a screen shot.
                    As for the toolbars. I only use one or two menus from each toolbar. I wish I could combined the tools into my personal toolbar, then I wouldn't have all the toolbars displayed.
                    Ken
                    • GaieusG
                      That sea is pretty cool, indeed!
                      At least with (most of) the native SU toolbars you can do this with Jim's custom toolbar plugin:
                      http://sketchuptips.blogspot.com/2008/06/custom-toolbars-release-08-06-01.html
                      • S
                        schnydix
                        Hi Tig
                        is there any chance to translate your plugins to other languages
                        i will to it for you if you like especial in german.
                        And thanks for your wonderfull work and time that you invest.
                        Big Respect to you Thanks again.
                        i also have some ideas for some plugs are you interest ?
                        I hope you can still read this simple code
                        • TIGT
                          @schnydix said:
                          Hi Tig
                          At the moment my recent tools don't support my 'deBabelizer' lingvo translations...
                          However, I DO plan to update them soon... so... watch this space... ๐Ÿ˜•
                          If you want to PM me with Plugins ideas please do... ๐Ÿ˜‰
                          • TIGT
                            Here's an update - http://forums.sketchucation.com/viewtopic.php?p=293698#p293698 - see link for download...
                            The Clone menu typo is fixed.
                            • thomthomT
                              Does it affect the undo stack?
                              • TIGT
                                The Image Animation is run inside a separate timer for each Image... so it shouldn't ?
                                BUT I think it might mess with the undo stack as it is changing the images properties!
                                It's over a year old... any ideas on this issue welcomed... ๐Ÿ˜•
                                • thomthomT
                                  I was curious if you'd found some way to avoid the undo stack.
                                  The only way I know to do changes to a model without affecting the undo stack is the .move! method. Been wanting some other means.
                                  There is the transparency arguments of start_operation - but they are troublesome as well. I find while they make your operation transparent - they still affect the undo stack as in the name of the last operation is replaced.
                                  And in your case - where it triggers by a timer - start_operation is not good as it would break any existing operations.
                                  There are several times where I'd like an observer to do something - like just adding an attribute - without affecting the undo stack. But alas I've not found a safe an reliable method. ๐Ÿ˜ž
                                  • TIGT
                                    In the other thread where we have been discussing this http://forums.sketchucation.com/viewtopic.php?p=379649#p379649 I expound on using 'save' to clear the undo-stack... but its 'mucho-clunkio' ๐Ÿ˜’
                                    • D
                                      Don-Quixote
                                      I changed your .ico with this set.
                                      ImageAnimatorIcons.rar
                                      • TIGT
                                        Here's an update: http://sketchucation.com/forums/viewtopic.php?p=293677#p293677
                                        The SKMtools Temp folder that is needed to process Image files etc, is now made in the User's Temp folder [OS specific] rather that the ../Plugins/SKMtools folder, avoiding potential permission issues...
