    Follow me tool on multiple surfaces
    16 Posts 9 Posters 4.0k Views 9 Watching
      artiscon
      hello, my first post, I hope it makes sense.Is there a way to use follow me tool on several surfaces ,instead of doing it on one surface only and repeat it several times?.I have to model pergola (paralell rails) along one complex path(which I have "welded)
      thank you
      tony
        Hi Tony,
        There are some plugins that can do PushPull on multiple faces but I cannot remember (or find) one that would do the same with the Follow me tool (or any kind of "extrusion").
        Would these pieces be identical when finished?
          artiscon
          Thank you Gaeius...yes, all identical.Those twenty pieces go around the edge of the wall (which have complex shape).I have drawn the path,"welded" it and have to use follow me tool twenty times.I was thinking I could do them with one click?
          thanks again
          Tony
            Hi Tony,
            In this case I would only make one of these pieces, make it into a component and distribute it along the path with either a simple linear array, around any circular curve (if there is any) with a radial array or along a more complex path with a ruby plugin (knowing what the path would look like could give me an idea which plugin maybe, something like PathCopy or Component Stringer would do).
            This would have the advantage that if you later modify any of the components, all the others would reflect this change.
              I don't believe that a real "multiple follow me" exist πŸ˜‰
              Pusp push multiple yes by fredo 6 Joint Push Pull
              Line2tubes yes (for a square take 4 as precision)by Didier Bur
                artiscon
                Thanks for the help
                t.
                  raffy
                  hi,
                  is there anyone can help me to find the component stringer plugin....i tried so many time searching but i didnt find any installer...
                    Hi Raffy and welcome!
                    Here you can find it attached to the top of the post:
                    http://forums.sketchucation.com/viewtopic.php?t=23616
                    • onzkiO Offline
                      onzki
                      Hi there, I saw that this thread was first started back in 2010.. any solutions to date? Just want to resurrect an old query. I appreciate your help, I find my self in need of such plugin because I'm doing a steel railing that has multiple shapes and if only a multi-face follow me exist, it'll be easier for my current task πŸ˜„ Thanks!
                      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                        The 'path' doesn't have to be 'consumed' by the new geometry, locate it well below the faces to be FollowMe'd.
                        Then Pre-Select the path and activate FollowMe, click on the lowest face, a profile is made.
                        Next Re-Select the path and activate FollowMe, click on the next face, a profile is made.
                        Repeat till done.
                        Use shortcuts: for Select it's <spacebar> and FollowMe can be given one - like Alt+F
                        This makes the steps only a few more than if a single tool did it...
                        However, here is a code snippet that does it for you !
                        Tips:
                        Ensure that the faces to extrude have their 'backs' to the start of the path.
                        Ensure the path is NOT going to be 'consumed' by the extruded geometry, by placing it below the lowest face.
                        Pre-Select the path AND the faces, do NOT include any faces' edges.
                        Then copy/paste the code into the Ruby Console +<enter>
                        m=Sketchup.active_model; s=m.selection; m.start_operation('xf'); s.grep(Sketchup;;Face).each{|f| f.followme(s.grep(Sketchup;;Edge))}; m.commit_operation;
                        All of the face FollowMe along the selected path in one go.
                        It is one step undo-able.
                        • ntxdaveN Offline
                          ntxdave
                          You could also look at something like the Profile Builder plugin/extension. You might need something more than the free version so that you can build your own profile. If you buy it, you can build any profile you need and it will then use that profile along a welded path.
                          You can find it at http://www.smustard.com The full version (where you can build your own profile is $20. I use the "free" version quite often.
                          Press F1...thank me later
                          • BoxB Offline
                            There is a simple workaround for this that people often miss.
                            Just draw a circle around your group of faces and extrude that.
                            Tiny bit of clean up and reversing of faces and away you go.
                            • pbacotP Offline
                              doh!
                                Tricky but faces must be with preference perpendicular to the start path! πŸ˜‰
                                • onzkiO Offline
                                  onzki
                                  Tips:
                                  Thanks a lot, I'll give this a try.
                                  • onzkiO Offline
                                    onzki
                                    Haha.. I like this trick. I'll give it a try, I never thought about this technique before. Thanks for sharing πŸ˜„
