Do you know where I can download Sketchup 7.1 free version?
When I google it, it leads me to 8.0. I am using the VRay plugin and want to keep everything the same so that it works when I render my model.
Your advice is greatly appreciated!
Cheers.
You can get the Pro version at the following link, which will revert to the Free version after 8 hrs use.
If you are using Windows you can use SU8 and V-Ray. Just spesify the path to SU8 instead of 7 when it prompts you for the path.
If you are OSX use you need to wait until a patch it out I think. (I'm not 100% sure - 1.48.89 might already work...) -
How about Sketchup 7.0? I did not enjoy the updates of 7.1
have a look here:
think here you can download the version 7.1
Version 7.1:
http://www.filehippo.com/download_google_sketchup/6860/ -
I'm using V-Ray with SU V8.0. What's more I'm using the second-to-latest version of V-Ray, because I find the delay on SU start-up to be unacceptable with the latest V-Ray. You just need to make sure that, when installing V-Ray, you change the default installation folder from SU7/Plugins to SU8/Plugins.
Edit: I see Thom has already mentioned this...and that you're on a Mac, but I'll leave this in place to reinforce the message for other readers.
