    Do you know where I can download Sketchup 7.1 free version?
    7 Posts 7 Posters 6.9k Views 7 Watching
      make
      When I google it, it leads me to 8.0. I am using the VRay plugin and want to keep everything the same so that it works when I render my model.
      Your advice is greatly appreciated!
      Cheers.
        Jim
        You can get the Pro version at the following link, which will revert to the Free version after 8 hrs use.
        Error 404 (Not Found)!!1
        (sketchup.google.com)
          If you are using Windows you can use SU8 and V-Ray. Just spesify the path to SU8 instead of 7 when it prompts you for the path.
          If you are OSX use you need to wait until a patch it out I think. (I'm not 100% sure - 1.48.89 might already work...)
          • E Offline
            errror404
            How about Sketchup 7.0? I did not enjoy the updates of 7.1 πŸ˜†
            • broomstickB Offline
              broomstick
              have a look here:
              http://forums.sketchucation.com/viewtopic.php?f=15&t=40491
                sofie9536
                think here you can download the version 7.1
                Version 7.1:
                http://www.filehippo.com/download_google_sketchup/6860/
                • Alan FraserA Offline
                  Alan Fraser
                  I'm using V-Ray with SU V8.0. What's more I'm using the second-to-latest version of V-Ray, because I find the delay on SU start-up to be unacceptable with the latest V-Ray. You just need to make sure that, when installing V-Ray, you change the default installation folder from SU7/Plugins to SU8/Plugins.
                  Edit: I see Thom has already mentioned this...and that you're on a Mac, but I'll leave this in place to reinforce the message for other readers.
                  3D Figures
